There are at least two types of "hot" ground. The worst Oz ground gives a very high X signal and a very high R signal. The ground in the USA can also give a very high X signal but it usually gives a very mild R signal. This is one reason why a VLF and PI detector that works okay in the USA needs to be fitted with a ten turn GB pot here in Oz. A high X signal is usually associated with highly susceptible ground such as magnetite and its cousins. It readily sticks to a magnet but often has a very low R signal. In other words it may give a negligible phase shift on a vlf and a very low amplitude decay on a PI.
We have another type of ground that is highly mineralised and also conductive because of wet salt and this can be a true nightmare.
Another type of ground gives an unpredictable signal and therefore can't be cancelled by using any of the methods discussed on the forum. Apparently this ground is also common in some parts of the USA.
