SURF PI PROBLEM
  • daverave
    ok i will check my coil cable....and hopefully solve this problem.
  • BillG
    If you move the magnet in front of it and get no signal, but wave the coil in the air near the ground, you could be detecting the mineralization. If you wave it in the air well away from the ground, you could have a bad coil connection or the cable is loose or you soldered the coil wire to the coil cable and the solder joint is moving. Alternately, you have your cellphone in your pocket and are detecting it or picking up EMI from it. My bet is you have an issue with your coil/cable.
  • Qiaozhi
    Originally posted by daverave View Post
    im still confused cause i get no response from the magnet but if i move the coil around in the air on the beach it does give signals...also my dual field coil cause it gives a signal on the magnet at about 1" is that a problem ????
    If it doesn't respond to a whiteboard magnet, then it cannot be the Earth field being detected, as this is much much weaker in comparison.
  • daverave
  • daverave
    i waived the magnet in front of the coil like i would a coin and no response from the magnet..but dual field detector gave a signal about 1" away from coil.
  • Qiaozhi
    i received the whiteboard magnets today and guess what ??? i can go right up to the coil with the magnet and no signal !!! so looks like nothing wrong with detector....i tried my other surf pi with dual field coil and i get a signal from the magnet at about 1" from coil.
    Just want to check that you're testing this correctly ... you need to keep the magnet moving and not hold it stationary, as the circuit can only detect a moving magnet.
  • daverave
  • greylourie
    Does moving your Delay away from minimum change this behaviour at all ?
  • Qiaozhi
    how far away from the coil do i waive these whiteboard magnets ?????
    I don't know with the Surf-PI, but I would guess somewhere between 3 to 6 inches.
    The whiteboard magnet has a much stronger magnetic field than the Earth, so it will more than likely make the detector beep when it's close to the coil.
    Using a PI with bipolar switching, I've managed to eliminate the whiteboard magnet when it's less than 1 inch from the coil.
  • daverave
  • daverave
    ok thanks for the info about magnets.
  • greylourie
    DS Nano or clone interfaced.
  • Qiaozhi
    Originally posted by paku View Post
    I think this needs some further explanation as to what we're looking at here.
    Is this a modified Surf-PI? Can it only tell the difference between ferrous and non-ferrous when the target is actually touching the coil. That's what seems to be happening in the video.
    Does this only work on the bench in an air test, or does it work in the field?
    Can it discriminate ferrous targets of different sizes and shapes?
    A more convincing demonstration would be a test with targets buried in real soil.
  • Qiaozhi
    what is a whiteboard magnet ??? and where do i buy one ????
  • paku
