Originally posted by bernte_one
NES 500 Pi Rebuild
Biasing in electronics is the method of establishing predetermined voltages or currents at various points of an electronic circuit for the purpose of establishing proper operating conditions in electronic components.
Bias is to DC preshift of voltage and current from the Zero conditions to provide correct working point of TR or IC according its characteristic. Offset could be included in bias setting.
can somebody tell me what the word "bias" means
it is a marking on trimpot rv1 same on schematic
something like Offset?
Go! Go! Go! Bernte_one!Originally posted by bernte_one View PostS of Q3 go to timer / oszi from Pic Controller
D goes to GND of U3 and U4 lm358 ? (maybe Timing of 1st an 2nd sample works together with U4)
btw
one good think, i dreamed last night that i had a working detector with yellow led indicator on frontpanel (it is a good sign)
i think it was the nes 500
btw
Hi bernte_one good work on new layout, Ive been trying to work out the function of Q3
it appears to be some type of switch just not sure what it does ?
i have re-worked layout with sprint layout, part Placement is the same
but better holes, better copper tracks, exact part number from schematic....
can Export gerber, pdf , bw Image for all free to use like always
hope we can do it together
i made also brn pi from baron and my Impression is that he is/ or was good designer
For chronology, I think the version you start with should be included as well, bernte_one ? Please post the pcb and schematic you aim to improve.
NES 500 Pi Rebuild
Hello,
i am on the way to re-build the NES 500 Pi Detector.
As i know i was another Project from Baron66. (BRN Pi Digital and other Projects)
i hope i can get some help here to improove the pcb and shematic.Tags: None
(or my fantasy)
