I bought the components for this and built it as a kit some time ago. Picked it up again this year and decided to get it put on a stick and working properly.
I wound a 'basket' type coil, using 24awg plastic covered wire, on a former that's about 21cm OD and 17cm ID. The coil works quite nicely, it finds my wedding ring at about 25 to 30cm when the coil is hanging away from anything else.
The problems start when I try to use it on the ground, then it seems to pick up everything. I'm certain I don't have that much metal under my lawn, and I'm not about to start digging up to find out as it would like like the surface of the moon if I did. I think it was even tracking tree roots.
I think I read somewhere that the PI type of metal detector is best for the beach, and that is primarily what it will be used for, is this the case?
