MD array questions
  • MD array questions
    Hi folks,
    Some questions on possible detector array arrangements.
    I am gong to start building my towed array assembly, and I want to make sure I'm going down the right path before I start.
    Currently, I was planning to build 6 pulse detectors with separate mono coils. These coils would be placed next to each other in a staggered pattern like so:
    -O O O
    --O O O
    To give me a scan coverage that overlaps.
    I was going to enable each PI circuit for perhaps 100ms, disable, and move on to the next circuit and repeat. Each circuit would provide a separate detection output that I would read for intensity, i.e depth.
    Since I will be moving slowly, I would "scan" as I'm going, and not have the circuits interfere with each other, and allow each coil to be tuned to that particular circuit.
    I want to make sure this seems reasonable, or if anyone can point out any potential issues I might have. I know I would basically only get an all-metal scan, with perhaps only the ability to detect depth.
    I would really also like the ability to discriminate as well, which I cant really do with Pulse Induction. If I used something besides PI, such as VLF, which can discriminate, would I be able to sequence the circuits like the pulse? Or would turning the VLF circuits on and off like that not be stable? To turn off the PI circuit I will simply clamp the reset pin on the 555 which will disable the transmit and subsequent sampling. Would I be able to do something similar with a VLF setup?
    What would be a good VLF design to do something like this? I am intending to initially use 6 Surf PI boards. If that works, I will start customizing a board design around that design as the base.
    Any ideas?
    Hmm Why not just 6 FET's and a special circuit to fire them in your chosen sequence?
    We made an array of underground radar many years ago. You could "steer" the beam
    using software.
      Well, that's the ultimate intent, I probably should just skip to that. I was just thinking to try a known good circuit and components, but I guess nothing is preventing going right to that. My main worry is if the PI technology is the right way to go.
        Well VLF would not like being interrupted. PI wouldn't mind though you might get less signal as waiting for the next TX
        will allow your RX to fade a bit.
