I just built a Silverdog Surf PI and when I power it up there is no sound and when I connect the coil the FET slowly gets very hot.
I put a DIY oscilloscope on the coil connections and I see a square 54ns pulse, 46% duty cycle. The voltages seem to be fine. The coil is 24awg speaker wire, 6.9" ID and 29 turns, 1.7 ohms a little more with leads on it.
I'm guessing the PCB is okay but the coil is drawing too much power? To test a higher ohm I connected the rest of the speaker wire (on spool) in series with the coil for about 2.5 ohms and I still had a hot FET.
