Can pinpointer detecting thin chain?
  • Can pinpointer detecting thin chain?
    Hi nupi fans ! :hat
    I'm just curious, did nupi ever arrive at a final, best, operationally satisfactory, etc. PP model(s) ?
    If so, what thread page number and post number is it on ?
    Am I correct that the original thread was moved to archival storage due to the large volume of posts and was then superseded by the current thread ?
    How do I navigate to the final "end all-be all" nupi PP(s) ? (In this context, a thing considered to be beyond improvement.)
    Thanks,
    ToddB66
    At the top right of the page:
    Click on Settings > General Settings
    The set "Default Thread Age Cut Off" to "Show All Threads".
      Don't know its final outcome.
        Can-pinpointer-detecting-thin chain? Reply to thread.
        Qiaozhi,
        Thanks for the help, however,......
        After following the above instructions, I didn't see a button on the last page to activate going to the post where nupi shows his final PP design.
        I scrolled all the way to the bottom of that last page and saw two buttons, one was "Submit Reply" and the other "Preview Post" and also looked at all the options listed at the far left, but still didn't see an appropriate button that would take me to the desired post.
        What do you suggest ?
        ToddB66
          Originally posted by Koala View Post
          Koala,
          Thanks, however,......
          I clicked-on the address in your post #3 and copied the nupi drawing and specifications, but not exactly sure what you meant by your last comment. Did you mean you don't know if that hyperlinked address is showing nupi's final "end all-be all" design ? I assume that's what you meant; just want to be sure is all.
          ToddB66
            Qiaozhi,
            ToddB66
            If you go to one of Nupi's posts and click on his username next to the avatar, then select "View Forum Posts", you can see a list of the last 100 posts. For Nupi, this goes back to February last year, which should be old enough. However, I was unable to spot a "final" schematic anywhere.
            Alternatively, you can (for example) go to the Tech Foum, and see which threads have any attachments. If they do, there will be a paper-clip icon. Click on the paperclip, and you will see a list of all the attachments.
            Or maybe just send Nupi a PM.
              All is there in post #426:
                That explains why it didn't show up in the search results.
                It was posted on the 27th July 2014.
                  can pinpointer detecting thin chain?
                  Qiaozhi (and others who have helped.),
                  I took the suggestion (colored above) and sent a PM to nupi, asking him to advise where I can find his "Final" schematics and specifications for the Standard and Mini size nupi Pinpointers on Geotech's website.
                  Thanks Everyone ! :friends
                  ToddB66
                    I received the pm from ToddB66 and answered him.
                    I admit that I've screwed up the clearness a little.
                    WM6 is right.
                    But I would now change the value of R2 to the value 200k.
                    nupi.
