Magnum on steroids!
  • steaua581
    This is really sad what did Ivconic so bad that had to be thrown out? He did so much to help with this hobby
  • chevesne
  • reiv
    WTF?? Where is our "master" ? Very sad story...
  • Artyom
    Originally posted by perkun View Post
    My Magnum also works great.
    The THT board is checked and working properly.However, the author of the topic made a mistake with connecting the coil.
    When I started the detector according to recommendations from the forum the detector worked very bad.
    The third coil that is responsible for BG and DISC should be a separate winding not continuing TX!
    Correct coil connections are shown in diagram GM5
    [ATTACH]39849[/ATTACH]
    If you use a finished sensor from Golden Mask, then the third winding is used. If you do the sensor yourself, a third winding is not required.
  • Jakson30
    The picture is not completely visible...
    But what is the number of turns and what is the diameter of the wire?
  • perkun
  • Artyom
    Originally posted by reiv View Post
    This is THT version and I think that is the best analog VLF machine I ever had. Ivconic was right, veeery fast and deep. Discrimination is also ok. In high sens is touchy to sticks or others obstacles but it`s not a big deal. Definitely worth to make one.
    Hi. In your video, which instrument was the frequency? Are there errors and inaccuracies on the board? Describe the coil, the number of turns and the diameter. Thank you.
  • reiv
    8 or 18kHz selectng by switch
  • Nandor
    What is the frequency you are using? I have read this topic many times maybe someday I will build my own.
  • reiv
  • Koala
    Nice video thanks for sharing.
    How does it compare to your IDX.
  • Nandor
    Very nice job looks like a factory made MD. Have luck and find many great stuff with it! Its SMD or THT?
  • reiv
    Here is how it performs with stock 10.5" coil :
  • kaligula
    I would like to buy those pcb complete with smd parts if you give me good prices
  • bandito
    Someone doing this project is worth the time wasting
