Magnum on steroids!
  • Artyom
    why not connected to this contact. draw your wiring diagram which connect the shielding of the sensor?
  • SVEN1
    I just rec'd my search coil 9" Golden Mask https://thrace-detectors.com/product...olil-23cm.html
  • ivconic
    Originally posted by Artyom View Post
    Tell me, what kind of probe are you using? The size, number of turns and wire diameter?
    It is the same coil as on video i posted earlier on this topic.
    I tried to make closest copy of original Golden Mask coil:
    TX= ~0.7mH, 2.9 ohms + one more turn for 5th pin on connector, wire 0.45mm
    RX= ~6mH, 24.5 ohms, wire 0.25mm
    Don't exactly remember number of turns, usually i make more turns and than by measuring inductance i lower the number of turns until i get closest to desired inductance.
    That's why i never try to remember exact number of turns.
    I guess the closest you can get is to see this my Corel file.
    I scanned part of original coil (since my scanner is A4) best as it could fit, to get as closest to original dimensions and shape.
    I am using Corel 9 for long period, kinda used much on it. So you'll have to have Corel 9 to be able to open this file.
  • Artyom
    Yes i made few devices so far. Right at this moment i am in a middle of making another one.
    I went outdoor several times with the device. It is performing alright.
    It is tough for me to judge and be objective, ever since i got the Deus; every other I/B detector looks pretty funny to me.
    But i would say that this is quite decent detector.
    If you put GEB command on front panel; you will be able to adjust it quite right on hotrocks and minerals.
    It is the Disc which can be improved a bit, GEB is working just fine.
    Depths are relative... as at any other model. Depths are depending on type of soil, moisture, outer weather conditions etc.
    The very same story as with any other model in that range. Decent. Correct. Usable.
    2-tone feature is advantage. Works pretty nice.
  • ivconic
    Hi, Ivconic. have you had the device work in the ground? how to behave, what depth, what kind of reaction on the hot stones, etc. Thank you.
  • Artyom
  • CDI
    Originally posted by SVEN1 View Post
    If your lucky enough to have a 3-D printer you could make one.
    I will probably end up up making one using epoxy and fiberglass cloth. Like I did once before.
    Think I have something around here I can use as a mold.
    [ATTACH]37757[/ATTACH]
    [ATTACH]37758[/ATTACH]
    Interesting, same thing i tried with car bumper's, but in my case it was polyester resin, not epoxy.
  • SVEN1
  • CDI
    Originally posted by Altair View Post
    Where to buy?
    I don't know, never used enclosure like that.
    Check ebay...
  • Altair
    Originally posted by CDI View Post
    Where to buy?
  • ivconic
  • CDI
    Why the shape? What case is it going in please?
    Cause fit into Bulgarian case for Terminator, Golden Mask...etc.
  • Sean_Goddard
    Had some PCB's made up of "mag_redu_pcb" version:using 1206 sized SMD components.
    Should arrive this week Tuesday.
    I have been studying the schematics and PCB layout this morning.
  • ivconic
    Originally posted by scs View Post
    When operating the ground balance with this type of filter to a lot of signals from earth salts. Another reject ground channel similar in Tesoro Golden Sabre must. Many details of the change in tone .Faults in filters?[ATTACH]37751[/ATTACH]
    Actually GEB is working very fine and accurate at this detector.
    It is the DISC which need improvements, it is not quite accurate at higher depths than 10-15cm in a soil.
    Medium sized rusty iron pieces are easy fooling it.
    That's the only drawback at this detector (also explanation why it is so successful "collector").
    Thanks for the suggestion! I will try that way.
    What a coincidence; i am just making another TH unit!
    In a few days i will report here the news.
  • scs
    When operating the ground balance with this type of filter to a lot of signals from earth salts. Another reject ground channel similar in Tesoro Golden Sabre must. Many details of the change in tone .Faults in filters?Click image for larger version
