Originally posted by green
View Post
PI TX Settling
S/N isn't good enough with my bench detector to chart the ground sample while at constant current. Might have some ripple current that I don't see on the scope exciting the reactive component.Originally posted by Old cart View PostCould you also also do a chart of ground using the same techniques?
Have you tried stage 2? Have you changed your opinion on constant current vs constant rate?Originally posted by Carl-NC View PostI agree the simulation is not going to capture real-life nuances because of the over-simplified target model. But it does provide some good insight. Stage 2 of this investigation is to build a test circuit with a double-acting TX driver and 2 RX demods. I want to measure target responses for both TX cases exactly simultaneously.
