Stop building PI detectors!
  • #76
ID:	416942Click image for larger version
ID:	416943Click image for larger version
ID:	416944Click image for larger version
    Main technical characteristics
    Maximum depth of object detection (by air):
    Coin diameter 25mm to 36cm
    Helmet up to 1.5m
    Maximum depth up to 3m
    Indication:
    Visual graphic and text, LCD 122x32 dots
    Sound multitonal
    The search mode is selective, non-selective, PULSE
    Operating frequency range 4-12 kHz(IB), 400 Hz(PI)
    Supported sensors are non-resonant (multi-frequency),
    resonant (single-frequency),
    pulsed (single-coil)
    Supply voltage 3.7-6.0 V
    Current consumption up to 200mA (IB mode),
    up to 500mA (PI mode),
    up to +100mA with LCD backlight
    Sensor parameters ring resonant 200mm (IB), loop depth 1.2m x 1.2m (PI);
    Rod length adjustable (800-1400mm);
    Weight, no more: 2.0 kg;​
    • #77
      hi amigo
      yup, site had been closed... DJE gave you right link. i did not know about it,,, thank you both.
      anyway... i did keep much files in the Archive, Kolokolov and Schedrin, and you can find them easily.
      Hi amigo KT315
      Thank you
      I am interesting to build PI/ VLF machine .studying voodoo project but unfortunately there isn't that book in my country . ... other thing where is found your Kolokolov and Schedrin archive ?
      Regards .​
      • #78
        Originally posted by dj elektrik View Post
        Thank you .
        • #79
          Originally posted by aft_72005 View Post
          Hi amigo KT315
          Thank you
          Regards .​
          you have to know i do not make u-controllers' with color LCD projects. all my projects are intended on lowest layers of the people, poorest folks, the peasants, 'small people'.
          all my schematics are based on 'trash technology', their components you take from oldest PCBs you can find in landfills and trash cans around you, in your local terrain.
          so all projects with the chips - thats not directed to me. ask The English Gurus of the forum. BTW i do not see someone here who got result with VOODOO circuit.
          link on The archive https://drive.google.com/file/d/1pNU...usp=drive_link
          • #80
            yes ... one of the important notice .. is be available electronics component .
            in my opinion your doing good work .
            about VLF/IB with ordinary components I see in forum two circuits one by iviconic and second by other person .
            but It is not clear whether they actually work or not.​
            • #81
              see this circuit I ​ found it in internet , but I don't know is there are more about it.
              • #82
                this
