We do not discuss LRLs in the Geotech forum. Please go to www.longrangelocators.com if you wish to talk psuedoscience.
The LRL brigade use the term "halo effect" to describe something different to normal metal detectorists. The usual definition of the "halo effect" is the situation where salts in the ground [apparently] interact with a coin, thereby making it appear larger to the detector.
Although some coins do interact with salts in the ground, and iron certainly does, gold and silver are only affected to a miniscule degree, and often not at all. There is certainly no so-called "halo effect" as far as gold and silver are concerned.
Unless the ground is particularly benign, a VLF detector will lose depth in the ground due to absorption. In fact, some VLF detectors can lose as much as a third when compared to an air test. By comparison, PI detectors will experience much less depth loss in the ground.
which has comfirmed existence of "Tha Halo" effect,
