Garrett Ace 150 - Constant Beeping Issue
  • Garrett Ace 150 - Constant Beeping Issue
    Hello,
    I am having issues with constant beeping with the ace 150
    Anything after 2 sensitivity makes it malfunction and cycle/beep through all tones
    Troubleshooting performed;
    -Check coil connection is secure
    -Wrap coil lead tightly
    -Clean coil & coil cover of loose material
    -Replace batteries
    -Checked batteries are fitted correctly
    -Test away from anything metal
    -Tested another coil (Factory ACE 150 coil)
    -Tested coil in free air (not attached to pole)
    -Factory reset device
    -Took apart control box, ensured the battery compartment springs were making contact, ensured no components were lose
    -Set potentiometers to lowest sensitivity and tested. Would not pickup metal on sens on 1, but once changed to 2 it would go crazy again
    Any help is appreciated thanks!
    Here is a video of how it reacts;
    https://www.youtube.com/watch?v=XYDl...ature=youtu.be
    lol i had that problem to your gona laugh add switch mobile fone of to your check list, and keep away from wifi
      Outside away from anything, mobiles inside, the issue still occurs. It seems to work fine on sens 1 but then has to be closer then 1" to detect anything
        Is it doing this in other locations ? Has it gotten Damp? Dry it out slow with a hair dryer. Try again.
          It was actually in indoor storage for about 1 year. It does it inside & also 20 meters away from the home (no wifi out there )
          I'm going to buy some good alkaline batteries to put in tomorrow and test again
            Damp can do Wacky Things. Try what I said.
              Put better batteries in - no change
              Not sure how it could be damp being stored indoors, but took apart and dried like advised - no change
              I'm pretty sure a chip on it has gone. So I have ordered a new MD
                I had the same problem with Tesoro Cortes, it was damn MCU.
                  Parts is Parts. Now you have Spares.
                    Not sure what to do with spares... new MD is not a garrett
                    Please close thread
                      The first I'd have done: trying a different coil.
                      Because it's a bit expensive to throw away the whole MD just because the coil is defect.
                      If this doesn't helps the steps described in post #1 may help but usually it's something else.
                      At least now you're free to upgrade and can enjoy some MD with much better performance.
                        Yeh I did try another coil - see in original post. I followed post#1 but no avail either
                        Anyone ever used a BH Discovery 3300? This is the replacement
