Tracker PI updated.
  • Tracker PI updated.
    hi, it's new program version, layout and possibility to add LCD screen now.
    some corrections the shematic you can see also of.
    sincerely
    Click Here
    hello
    i have a tracker pi with lcd here
    but i dont know anything about it
    can anyone give me some details please
      hello, B1.
      hooh... oldie subject... can you give photos of your Tracker? there were several revisions of PCB, but a schematic maybe has not so too changed. have to look...
        When I click the link, I get a blank screen with these words ?
        Запрошенные данные недоступны
        файл не найден
          I do get the same. That’s how Google translate it
          '''The requested data is unavailable file not found"""
            old site has been closed. new one http://metdet.ru/PI.htm
              I have stumbled upon some info on the tracker 2
              this link will take you to a thread
              in the thread is a clickable link that will download a hex file and some pcb info on tracker 2
              chrome will convert the thread text to english, the text seems to say the hex is for newer ATtiny2313.
              Sensitivity 18-20cm at the coin 25mm diameter and up to 100-150cm for large metal objects
              the coil 27 turns in a solid copper wire enamel insulation diameter of 0.5-0.8 mm (.6mm is best)
              coil diameter 18-25cm.
              There are lots of dead end links on the net to this project.
              http://radioskot.ru/publ/metalloiska...pi_2/1-1-0-426
                Koschej-5I
ID:	334092Click image for larger version
ID:	334093Click image for larger version
ID:	334091Click image for larger version
ID:	334098Click image for larger version
Name:	plata Tracker PI.jpg
                  Koschej-5IM
ID:	334094Click image for larger version
ID:	334095Click image for larger version
ID:	334096Click image for larger version
                    guys, I give again a direct link on HOW TO MAKE DEEPER COIL FOR THE TRACKER
                    http://www.metdet.ru/GL12x12.htm
                    follow the text and pics.
                      Tracker pi /xr71. who is best?
