BYK1337 connected a 9v power adapter to his new scope. An unregulated power adapter output voltage is typically 1.4 to 1.5 times rated at low current draw. Probably wished he had measured the voltage before connected to his new scope.
Wish I had remembered to switch the scope probe to X10 when measuring PI coil volts.
Wish I had shorted the multi meter probes together to charge the power supply capacitors when trying to measure my PI detector current draw.
Wish I thought more about what I was doing the other day testing for EMI shielding. Connected a sheet of aluminum foil to +battery with a jumper lead. + battery was common when using a mono coil. Now control logic is 5volts with -volts connected to -battery. Foil touched an exposed control logic pin while I was trying things. Didn't like 12volts. Now I have to build another logic controller.
I would guess others have something they wish they could do over. I need to slow down and think before I do.
