Looking for a new selfmade Detector
  • Looking for a new selfmade Detector
    Hello i am looking for a detector that can find gold and other metall but i want to have different sounds is there a projekt like this
    I can do the difference between black metal and non-ferrous metal
      You could make the Tesoro Golden Sabre Light. You can discriminate other metals with it.
      There is also a version with two different tones for Iron and non Iron metals , called the IGSL.
      I have boards in production from a smaller version of the TGSL and i can sell you one , but they are not tested yet and still in transit.
      You could also buy pcbs from silverdog.co.uk or a kit.
      If you want to make your own boards then check the TGSL Thread here in the forum.
      There is also a well documented PDF for the TGSL EDU.
        tsgl, is an option but it is quite an advanced project, less skilled builders have had problems getting them stable, I don't know if this is the unit or its coil as both are hard to fine tune.
        the idx is a good vlf project with just as many mods and tweaks it seems, I bought an idx kit but as a repair path for my whites idx the the board craps out.
        if you go for the golden sabre I would edge your bets and go for the ivconic version, there is also a way to use minelab musketeer coils, I would look into that, or failing that buy a genuine Tesoro coil the correct type, make it as easy as you can on your self.
        a good working coil will remove any doubts when you are trying to set it up, it really
        is
        worth it in the long run, once you have a good working machine then you can try building a coil yourself, building the coil makes a hard project even harder so make it easier.
          I dont think that the board is hard to fine tune. Its the coil.
          You should watch the TGSL build Video from EPAE on Youtube.
          A factory made coil cost about 100-140 Euro for the TGSL. You can make your own for 30-40 Euro. But its not easy for a beginner.
