Minelab Equinox Challenge
  • EL NINO
    Now I have made new scans of the Specs V3 Y-log ON, and Y-log OF-Linear.I personally prefer Y axis-Linear..X axis-Linear=-Y axis-log-Off...,X axis log-Off.
Name:	V3 multi Y-log ON.JPG
  • green
    Originally posted by EL NINO View Post
    Spectra scans I made a few days earlier ... and on another laptop .., Yes, using the Y axis axis you can move down some weak harmonic frequencies .. but the last 2 scans The V3-normal-and-Bost spectra were made at the same settings ..
    My question, is there a preferred way to chart the data for this application? linear-linear, linear-log, log-linear or log-log. I'm think log-log but just a guess.
  • EL NINO
  • green
    Hi EL NINO
    Curious why some of your FFT charts have linear y axis and some have log y axis. Would it be better to use log or linear x or y?
  • EL NINO
    For comparison, SpectraV3: I give the 3F multi scans :all multi programs are equal in normal/ salt ....So I crowd in Tx normal/TxBost from Whites Spectra V3.
    Frequencies for Spectra su Enough-matching-balanced- with Concept Spectra:....Optical Analysis of Signal and Frequency-Based Response Force on 3f-Spectragraph,... 3f-Signagraf,... and 3-fpinpoint by Spectra Detector Users.
  • EL NINO
    ...Skippy.. I fixed the last scans 1F ....
  • ivconic
    It is probably my own prejudice, generated through the years of playing with these toys, yet;
    i tend to believe in "magic" 5-9kHz range, which gave me the very best of performances overall on all the real terrains, fields, sites... i've been visiting so far.
    At the very beginning with the Deus i was amazed with 18kHz and sensitivity on smallest coins.
    Some 7 years later i am constantly running it only at ~7kHz.
    Why? I guess i don't need to answer why. It is self-explanatory.
    Despite my "forum antagonism" towards ML; fact is that those are pretty smart and conversant guys working there.
    They do know the job well.
    Whether they will disclose everything in white paper; that's quite another thing.
  • Skippy
    ElNino: Your last post of screenshots has errors, 'no attachment' for some of them. Can you repost them, please?
  • EL NINO
    ...On my laptop -196 / 24bit Laptop card, I can not get more than 96000s / 35,000 FFTs from the VA program. So my next trip will be buying an oscilloscope ...,. Comparing Park1 / Park2 scans and direct sensitivity comparison of these programs to small things can be said - even beyond the many RX signals operating, a different preamp RXgain per each of the 3 received frequencies ... What makes sense. The low 7.8khz frequency - indeed, it has been chosen for universal targeting, lower power consumption, lighter coil, and better groung balance adjustment.
  • bklein
    Carl, would an old Tek AM503 current probe be a worthy substitute for your opamp circuit? (Clip on TX)
  • Carl-NC
    The more you oversample, the more accurate the results. At 1MHz you only get 25pts per 40kHz cycle, I wouldn't go any lower. The scope I used is 1GS/s.
  • Mark-VA
    Sir, would the sample rate need to be the same for each frequency?
    Or does it need to be adjusted to make more visible sense?
    I guess, what I'm asking, is there a universal sample rate that will give the best wave, or rather the most truthful looking frequency?
  • Carl-NC
    Ugh, the sample rate is just awful. Here is what you should see:
    Top trace is Beach-MF and bottom trace is Park MF. Here is Prospecting-MF:
    Note the 40kHz is slightly modulated at 5kHz.
    Here is single-freq @ 5kHz:
    The tau of the coil really starts to show up here. If Minelab bumped this up to 7.8kHz as some people claim, it was probably to improve battery life.
  • EL NINO
  • EL NINO
