smooth like mine a-s. but very smooth! RUN BACK! get UNIDEAL! get OVER-DAMPING NOT DAMPING!
How does the pulse detector coil and damping resistor smooth the waveform?
No, the waveform is good enough, but the depth is not good! Asian women are beautiful?:大声笑:Originally posted by kt315 View Postwhat you mean is not BEST? those asiatics women around you are best? LOL ))) begin from 2k2 - give the pic
1k - give the pic
820 ohm - give the pic
680 ohm - give the pic
My coils are 320uh and 1.9 ohms. It is a multi-core cable made in China. I also think it may not be tight, causing an abnormal distributed capacitance.Originally posted by Carl-NC View PostI think you have a different problem somewhere. A damping R = 680 should be "close enough" to make it work. Look very closely at resistor values, make sure there are no mistakes.
Do you have an oscope? Remove the damping R and measure the ringing frequency. You can calculate C from this, standard w=1/sqrt(LC). You can also wiggle things to see if the frequency changes a lot, indicating problems.Originally posted by wyl123 View PostMy coils are 320uh and 1.9 ohms. It is a multi-core cable made in China. I also think it may not be tight, causing an abnormal distributed capacitance.
I don't know why people have problems with easy circuit like dp. I am novice in electronics, but never had been situation in which it became mission impossible. Work the problem methodically, step by step. You will find answer.
That Requires Problem Solving Skills .Originally posted by dbanner View PostI don't know why people have problems with easy circuit like dp. I am novice in electronics, but never had been situation in which it became mission impossible. Work the problem methodically, step by step. You will find answer.
