G'day,
I have had major problems with condensation forming inside my detectors and damaging the circuit boards and also damaging the batteries (the detectors are used in an area with regular heavy rainfall and moisture laden air). I even went to the extreme of of buying a diving detector (fully waterproof) to use on land. But I found condensation would still appear inside the sealed (waterproof!) detector and it took just a pin prick of rust to form on the edge of one battery (of 7 batteries) to short it. The major problem, in that instance, was that I wasted a lot of time trying to find out why it was not working. The rust spot was so small it was just about invisible and it didn't even occur to me at the time that rust could form to be a problem.
What I would like to know is ... can I regularly spray WD fluid ( https://www.wd40.com/ ) on the electrics, and batteries, to prevent any condensation building up? In effect using the WD fluid as a preventive measure.
Rob (RKC)
Rob (RKC)
