EXP 600 "future series"
  • EXP 600 "future series"
    Hi every one
    i was watching videos on youtube present and describe a metal detector called "EXP 600".
    this metal detector from a German company which is called "OKM". here are the URLS:
    this detector as they mention is one of the "Future series".
    what grab my attention is this detector use uncommon sensor shape! this sensor is just a stick used horizontal or vertical!
    what is going on guys! is this real! does this detector use a different technique! or it is just a scam!
    It's a magnetometer, not a metal detector.
      A Magnetometer! It is interesting, but is it reliable when it use to locate the buried metal objects?!
      what is its limitations to find metal targets?
      the magnetometer as i know it is able to sense the distortions in the magnetic fields of the earth
      so theoretically it is not able to detect non ferrous metal like gold and silver!
      I think this device is usless when it is used to locate buried treasure and the cliams of the OKM is not real!
        PLEASE DO NOT CRY. iwgonik does magnetometer and you can do with him. its will free if i noticed right.
          Yes, a mag is very useful for locating ferrous targets. It can also be used to generate a magnetic map of the ground which (under good conditions) might be able to show disturbed ground or voids. But it cannot detect gold or silver directly, at all.
            thanks Carl-NC for your replies
