MD Physics
  • green
    Your coils look OK, I guess the resistive loss caused by the solder that's between the ends of the copper is offset by the extra solder around the outer of the wire? I guess for large loops like 40mm+ the contribution to R from the solder is small.
    Example: if solder has conductivity of 10% IACS, then 0.1mm of solder in the joint is like 1mm of copper, which out of, say 120mm ( Pi x 40) is only a small error.
    Edit: that increase/decrease thing is bad proof-reading ... I originally typed R increased, then I changed it to TC, but forgot to change the 'increased' to 'decreased'.
    And no, I didn't use the online calculator, I did it properly on a pocket calculator. Now you've forced me to turn on javascript and try the TechNick thing out, I can confirm it does in fact work.
    R = 0.02
    a = 0.0004505
    N = 1
    ur = 1
    gives L = 9.7328..... x 10e-8 = 97 nH, as previously.
    I should ask: is 40mm the mean diameter ? If it's the inner diameter, you'll need to adjust the calculations.
    Thanks. Stupid pill, kept making the same error, needed another .0 in wire radius. Calculates about 10% lower than my measurements(L=TC*R) for the three coils. Don't know where the difference is but close enough.
    I should ask: is 40mm the mean diameter? If it's the inner diameter, you'll need to adjust the calculations. Wire was cut to length, then butted and soldered.
  • Skippy
    R = 0.02
    a = 0.0004505
    N = 1
    ur = 1
  • green
    The effect of the solder join could be investigated by making rings with 1, 2, 3, 4, 5 joints, and seeing how TC varies ( increases) ... the trouble is making a perfect cut without removing much metal. Why increase? Adding resistance should decrease TC.
    Made another 80mm diameter coil(coil B). Recorded coil A and coil B, 1 join. Cut coil B and joined with 2, 3 and 4 joins. Recorded after each join. My cutter cuts a flat on one side of cut, then cut other side flat. Loose about 1mm cutting other side flat for each of the 2, 3 and 4 joins. Don't see much change in TC.
  • green
    Gotta admit, I don't like the idea of soldering a loop of high-conductivity copper up with a random blob of low-conductivity lead alloy. Maybe it was not leaded solder, but lead-free? Was it a neat butt joint, with flat faces, or did you just chop the wire with cutters and leave that distinctive chopped taper etc? Did you file the solder down afterwards, or leave a spherical ball on the join ? Etc Etc?
    Anyway: Case C , with the 10a + 9b bit in the formula is no use for single turns, ... it's for solenoids, I think?
    You've obviously got L calculation problems, you're miles out, but your R value looks good.
    Here's my maths for the 40mm coil:
    Loop resistance = 3.25 mOhms ( using 1.68 x 10-8 for resistivity )
    Loop inductance = 97 nH = 0.097 microhenry
    So Time-constant = L/R = 29.9 microsecs. Which fits nicely with the measured value of 33 usec.
    I'm beginning to regret not starting the 'Ring target thread' now, we're going to have to copy stuff over.
    Did you use https://technick.net/tools/inductanc...circular-loop/ to calculate inductance?
    Used kester 60/40 solder. neat butt joint, with flat faces, spherical ball on the joint. AWG19 magnet wire.
  • Skippy
  • green
    Mihkel:
    There's also this thread, which is intended to be about making/modifying a PI detector to make it suitable for target testing. Mr. Green and Eric F. have both got some working setups.
    But towards the end of it, I did a simple model of a square sheet of metal, by assuming it was a ring/loop. This is relevant to your finger ring testing. Posts 107 onwards are the significant ones:
    I forgot to mention in that thread what the inductance calculation was.
    Here is an online calculator, showing the formula for inductance of a loop:
    Wondered how close to calculated inductance some wire loops would be to L=TC*R and how much the soldered joint would effect loop resistance. Tried technick calculation and one I've used in the past, LuH=r(inches)/9 for a single loop. Nothing close, wondering what I am doing wrong. Cut some AWG19 wire to length, wrapped in a circle and soldered. Recorded decay.
    targets same location, centered on one of the 200mm fig8 coils.
  • pustareka
  • Skippy
    Relative perm = 1.00 for air or a vacuum
  • green
    Mihkel:
    What do I enter for relative permeability?
  • MTammet
    I will try to get similar presentation. I will use your drilled zinc pennies for reference. As you noticed from my graph 2 eurocent is pretty close to zinc (it is steel) penny so I will drill it to.
  • Skippy
    Mihkel:
  • MTammet
    Thank you Skippy! Was interesting and educating reading.
    Mihkel
  • ifrenide
    Hi.
    I will make 2 leds vdi or maybe more. pic microcontroller based vdi with LEDs will be simple .
    Thanx
  • MTammet
    Will add results in graph. Asked my friend K. Märtens. Unfortunately in Estonian. Horizontal unit 10 micro sec, vertical signal strength. 1. item -gold gilded baby copper ring 1,6 gram, 2. Bronze with nice patina 2 gram, 3. 2 euro cents for comparison, 4. Bronze with nasty Cu2O 4 gram, 5. Roughed copper ring 2,4 gram. Will post graph and pictures. When I made measurement with Vallon I also understood my mistake in interpretation. I measured those two rings at normal mode when changed to mineral the results are very similar with the graph. As I have understood Vallon is designed to find pcb tracs related to IEDś which are copper coated with.... It is probably because otf that internal firmware tuning that there is this enermous difference in normal mode.Click image for larger version
ID:	352303Click image for larger version
ID:	352304Metallobjektide decay-d.pdf
  • ifrenide
    Please help me to understand slopes and average of slopes related to R and X signals to use it in coding .thanx
