Hello.
May I ask somebody to advise? I set up the Surf PI 1.2. When trying to increase the performance it stopped working offset, when setting to 0V 5534 does not respond, even without NE 555. All measurements on the integrated circuits (I tried to change the new ones) are correct, unfortunately to the measurement I have only a multimeter . I have done so by eliminating C17, changing C6 to 220mF, and adding 100pF between pin 2 NE5534 and D1 D2.
This is an adaptation of a shema from a former member of the forum, so I did not try.
Do not you know where there might be a reason why you can not set 0-V on offset? On rotation
does not respond.
does not respond.
