I sent you a PM.
Can i use 1N4148 instead of BAV99?
I need to replace this transistors:
BC817 --> BC517
BC807 --> BC507
BC856 --> BC556
Can i use 2N2222 and 2N2907 too?
Surf PI Micro Var. 1.00
Would you be interested in selling one PCB, thanks ?Originally posted by BKY1337 View PostHi,
i have 20 pcbs from this project: https://www.pcbway.com/project/share..._Var_1_00.html
My Problem is that i dont have a bill of materials. I dont know which Transistors i should use.
I can find a schematic from the smd version but i need tht parts.
I can find the majority of the parts at the silkscreen but i need the missing parts.
[ATTACH]44337[/ATTACH]
English please -> Basic Rules of the ForumsOriginally posted by Andi68 View PostOhne Gewähr, hab ich auf die Schnelle rausgesucht
Not necessary, you just have to check if the type and the occupancy are correct
Thanks. I never made any smd project.
Then i will try to flash my first microcontroller and populate a board.
change first '8' on '5' in a trans type and you get equvalent. no secret, everyone knows this rule.
Hi andi,
i already saw this schematic. But the problem is that it uses smd transistors, i need the tht equvalents for it.
The linked project description contains a wiring diagram
Tags: None
