winter project
  • winter project
    Hello,
    I'm looking for a project for winter, PI, but I do not know which detector to build.
    Do you have any inspiration for me?
    greetings
    Originally posted by Andi68 View Post
    Hello,
    greetings
    CLONE PI-W
    nacinay- start
    usb--asp
    Zhurov Pavel.rar
    USBasp-win-driver-x86-x64-v3.0.7.zip https://gofile.io/?c=Sz3Ngf
      Hello,
      greetings
      Which PI detectors have you made so far?
      Where are you intending to treasure hunt (beach, inland, Australian outback)?
        What about Pi-Tone (Python).
        Its a simple Pi Metal detector but uses a microcontroller.
          I built the Surf, Baracuda and Sandbanks clone.
          Even the pirate, but I did not like it.
          I am searching in Germany, inland.
          A circuit without microcontroller I would prefer
            That's a lot of PI detectors so far. I'm not sure about your goal, do build again only PI. Would it not be more interesting to try a VLF, to separate the difference in iron and not iron?
            I would suggest IDX-Pro in this case, because it's not complicated, but with a good range.
              Держи Tiny 2002 !!
              Bauteileliste Tiny 2002:
              U1 NE555
              U2 LF357
              U3 HEF4053
              U4 TL082
              U5 HEF4528
              U6 HEF4528
              U7 LF356
              U8 NE555
              U9 CNY17
              U10 ICL7660
              U11 78L08
              Q1 MTP2P50E (PMos/500V)
              Q2 BC547
              Q3 BC547
              Q4 BC557
              D1 1N4007
              D2/D3 1N5817 (Schottky)
              C1 4700yF-10000yF/16V min.
              C2 10nF Mks
              C3 33nF Mks
              C4,C5,C6 100nF Mks
              C9,C7 3,3 nF Ker.
              C8 47nF Mks
              C18 330pF Ker.
              C17,C16 100nF Mks
              C10,C11 10nF Mks
              C15,C14 470yF/16V
              C13,C12 47yF/16V
              R1 2K - 2,2K/Metallfilm/2W
              R2 1K / Metallfilm
              R3,R4 1K
              R35 10K
              R5 68K
              R6 5,6K
              R7 560
              R8 1M
              R9 50K/Trimmer
              R10 560
              R11,R12 10K
              R13,R14 1M
              R21,R22,R23 10K
              R24 15K
              R25 10K
              R15,R16 2,2M
              R26 1K
              R17 4,7K
              R27 100K
              R18 150K
              R28 1K
              R19,R20 15K
              R29 22
              R30 22K
              R31 22K
              R32 220
              R33 1K
              R34 Poti 10k mit Schalter
              R35 10K
              Sonstiges: Nullohm Widerstдnde oder Drahtbrьcken. Alle schwarzen Widerstдnde auf Bestьckungs plan sind Nullohm bzw. Drahtbrьcken. Bitte nicht die Drahtbrьcken unter U1,U6,U5,U8
              vergessen. BNC Einbaubuchse + Stecker fьr Spule Klinkenbuchse fьr Lautsprecher oder Kopfhцrer
              NC Akku 10Zellen (12V) mit Ladebuchse.
              Knopf fьr Poti.
              Der SpulenanschluЯ braucht nicht isoliert eingebaut werden, da bei PMos die Spulenmasse auch die Masse des Systems ist !!
                If you're searching inland, then you should probably go for a VLF design like the TGSL.
                Otherwise you could try the Minipulse Plus if you want to build another PI.
                  i think his winter project will be Quasar ARM and pustareka will tell us about in his too wild russospanglish.
                    Last winter I put together a TGSL and I was rather pleased with it (best season of metal detecting loot), you can also try the IDX pro, or a lobo, All three of these are VLF, for inland would be a better choice over a PI, you can easily find used or new coils for them if, making your own VLF coil is out of your technical knowhow
                      King Cobra is open project now, like i promised and done. you can order PCB yourself and sell them where you want - in this forum or ebay, in any amount you want.
                      you also can call it like you want. FULLY FREE.
                        Andi already has a lobo. I think he doesn't want to build a vlf.
                        I think he likes the Tiny 2002.
                          http://www.geotech1.com/forums/showt...-version-build
                          Да, хорошо si claro. Ok KT315.
                            Tiny 2002 super tunned sens cook pan to air 1.8m, coil 40cm. Exelent proect.
                              Hello,
                              greetings
                              Since you have built several PI detectors that do NOT use a microcontroller my suggestion is to go for one with a microcontroller.
                              This allows a lot more experimentation of pulse and sample timing as well as Ground Balance, etc.
                              Check my Hammer Head project using a microcontroller (PIC processor) to see what experimentation can be done.
                              A basic PI design incorporating a PIC micro for timing control, intended as a learning platform for using uC's.
                              Also sounds like LEARNING to program a microcontroller is a good next step for you since they are used everywhere now and for very good reasons.
