Is this detector built by hybrid technology ?
This video shows the behavior of the prototype ( search head – 26 centimeters ) of the theme - Thread: Real tests. This is a science ... – Geotech , Tech Forum , 10-26-2018, 08:55 AM . The test is done with a stone of pure magnetite . The black stone from the video weighs 1250 g , its volume ( displacement ) - 0.27 liters - iron ore. ( I'm sure
that Fred Flintstone and Barney ( Family Flintstones ) from Bedrock at the time stone Age - they used similar stones for core of prehistoric transformers
) and he has a very strong reactive components
visible on the videoclips . The detector is set to medium sensitivity of this video , but even the maximum sensitivity (a coin of 10 euro cents -38-40 centimeters , 2 euros - from 46 to 50 centimeters , very weak signals , test in the air ) is not overloaded by this stone , only gives more noisy reactions to the stone . The video clearly shows some of the most important points on which some conclusions can be drawn , and brings a lot of information about the eye of a professional . It also shows that there is no loss of sensitivity to the targets behind the stone . I tested the model of Minelab – GPX 5000 ( search head was 27 centimeters DD ) with this stone . Of normal sensitivity is impossible completely cut it . You have to significantly reduce the sensitivity of this detector in order to avoid any reaction on the stone . In an induction balance type detector test , the signal from the stone is about 3 times stronger
, than that shown on the video vise ( press ).
What do you think – whether this prototype is based on hybrid technology? Crossbreed between induction balance and PI ( pulse induction ) . Or not ?
Because many things in this world are correlated , predictable , I expect a small number of members of this forum to say their point of view . We are unlikely to hear the opinion of professionals - they are quite cautious… As seen on the video , discrimination is insecure for targets less than 2 euros , behind the stone targets it is impossible to recognize whether they are made of iron or not ( I was correct , I also show the detector's reaction against iron targets ) . Even with the most advanced pulse technology only the time constant of the target can be determined , but not whether this target is iron , or is of non-magnetic metal .
Thank you very much for your attention . Thanks in advance for any opinions .
, than that shown on the video vise ( press ).What do you think – whether this prototype is based on hybrid technology? Crossbreed between induction balance and PI ( pulse induction ) . Or not ?
Advertising prototype which is not intended for sale is pointless , nonsense . If you have not understood it yet , I'll tell you that – this topic shows tests that greatly help mental activity
lectures of the inhabitants of the earth ???
