How does ground balance work in GPX 4500?
  • Qiaozhi
    Also, read this thread from post #69 onwards -> http://www.geotech1.com/forums/showt...ead#post208718
    It describes a GB method proposed by Teleno that doesn't generate a hole in the detector's response.
  • green
    The numbers in the PNG file are what was required to balance California ground. Ground from the back yard balances very close to if not the same settings. I'll try to answer some of your other questions later, need to do some yard work.
    Couple charts I posted in other threads. TRT_21, example of ground slope changing with Tx on time with constant current Tx vs constant rate Tx, each would require a different balance setting to cancel ground signal. target delay_1, some data taken awhile back showing detection distance and integrator out volts with some different targets. GEB on causes distance loss because noise increases when the 100usec GEB sample is added. I use a(Rx, two 8inch round connected figure eight)(Tx surrounds Rx)reduces noise and ground signal. Don't think it would have different timings vs mono coil. I did bury a target in back yard 10inches deep to see if integrator out voltage was the same as air with GEB on adjusted to cancel ground signal. Little or no difference.
  • kt315
    read also https://en.wikipedia.org/wiki/Convolution
  • belax2018
    https://en.wikipedia.org/wiki/Walsh_function
    Applications of the Walsh functions can be found wherever digit representations are used, including speech recognition, medical and biological image processing, and digital holography.
    For example, the fast Walsh–Hadamard transform (FWHT) may be used in the analysis of digital quasi-Monte Carlo methods. In radio astronomy, Walsh functions can help reduce the effects of electrical crosstalk between antenna signals. They are also used in passive LCD panels as X and Y binary driving waveforms where the autocorrelation between X and Y can be made minimal for pixels that are off.
    Thank you KT315.
    I can calculate an integral of f(t)=1/t^a. or understand why Minelab version of ground slope (in the pdf on their web site) is time invariant.
    But I am not a professor. That is new for me and I will need months to understand it.
    Have you ever done a repair of GPX series of minelab MDs? Maybe you can tell us how waveforms look like? What TX current slope looks like?.....
    Thank you again.
  • green
    Originally posted by belax2018 View Post
    Thank you green for real numbers.
    Would be interesting to know how much depth you loose with "your type of GB" in a real environment?
    I know there can be two factors of loosing depth (sensetivity).
    1) So cold "hole" in response - because of a curtain TC value (or a combination of TCs) of a target. I am not interested in this, as I am usually interested in low TC targets and here it is usually not the case.
    2) GB sample does not equally eliminates ground part in Target sample. I mean balance is not uniform over a slightly varying coil-soil distance or it is not uniform over soils with different density of minerals and so on. I don't know how to say it better. In other words how much do you need to decrease your "sensitivity pot" in order to work over the ground without constant false beeeps?
    1) You say you adjust target sample width. How much (approximately in %) do you usually change it from the values stated in PNG file to reach GB in California? I will try with your method soon when the whether let me.
    2) You mention ground slope depends on constant rate of TX current change. Here it would be very interesting to know what part of TX coil current slope Minelabbers use in GPX 4500. I have read somewhere that they prefer to use only first part of a coil current curve ( Icoil = V/R (1-exp(-Rt/L)) ), I mean the part which looks almost like a straight line.
  • belax2018
    Don't know about GPX4500. This is what I use. First delay is adjustable(6-20usec), first sample(target sample adjustable, used as ground balance adjustment), second delay(short 4 to 5usec), second sample(GB sample, fixed at about 100usec), EF sample time(second-first sample time)I take it just before Tx on. GEB timing.png shows settings to balance ground when changing first delay. Tx time, constant current or constant rate and probably others effect ground slope so changing either one could effect first sample time needed to balance ground.
    What I am interested is the following. GB sample does not equally eliminates ground part in Target sample. I mean ground balance is not uniform over a slightly varying coil-soil distance or it is not uniform over soils with different density of minerals and so on. I don't know how to say it better. In other words how much do you need to decrease your "sensitivity pot" in order to work over the ground without constant false beeeps?
  • kt315
  • Qiaozhi
    Read this thread -> http://www.geotech1.com/forums/showt...ground+balance
    It should answer your question.
  • green
  • kt315
    we must rebirth QED anyway and give gold nugget seeking winter project for every australian.
  • belax2018
    started a topic How does ground balance work in GPX 4500?
    Can anybody give a clue on how ground balance works in gpx 4500 machine?
    I am interested in theory behind it and a practical realization.
    I am building my own hobby PI machine with MCU, FPGA, ADC, and fully differential front end. My coil is a two coil concentric type. TX is a single MOSFET – classical tx design – not a bipolar.
    RX consists of two ad8139 + adc 40 msps + fpga.
    In fpga I can do any integrations. I mean I can set any delays after TX and any t1-t2 where I do integration.
    In MCU a do a configuration in FPGA (set delay and integration windows), also I do their oversampling, average values calculations and so on.
    The device works well in the air. However, when it comes to ground I do not get any decent results.
    I have looked through lots of pages in this forum studying the methods and theory behind Ground balance in monopole (single mosfet) PI machines. But cannot find a good working practical solution.
    Right now, my ground balance works like this:
    TX length is T=100 us.
    Delay 1 (t0 - t1): 8 us.
    Target Sample (t1-t2): 8 us
    Delay 2 (t2-t3), where t3=3*t1: 8 us
    Ground sample (t3-t4), where t3=3*t1, t4=3*t2.
    EF sample: 800 us after TX end, length of EF sample is Ground Sample length minus Target Sample Length.
    (P.S.: Sample means - I do integration of ADC values from RX coil in this sample window)
    Final signal for processing: X = Target Sample – Ground Sample + EF Sample
    Delay 2 is adjustable: So I do up and down with coil and adjust this delay until no change in signal is noticeable.
    However, as I said, that method does not work well. It is not very stable.
    Thank you.
