Summation
  • Summation
    I'd like to see a summation of the frequencies in relation to the Equinox Multi-IQ and the CTX.
    If it is possible.
    The two Equinox threads will tell you what it uses, in the original V1.5 firmware, and thanks to El-Nino, the different frequencies in V1.7.5
    The CTX uses the same frequencies as all the BBS/FBS/FBS2 machines:
    A single cycle of 3.125 kHz, followed by 8 cycles of 25 kHz, then repeat. These freqs can be shifted a significant way above and below, about +/-7% I recall, using the 'noise-cancel' , the frequency ratio of 1:8 (3.125 : 25) is always maintained, regardless.
