I would have guessed we would hear it here first, but
  • I would have guessed we would hear it here first, but
    http://hobby-detecting.com/fisher-im...e0Scgow5jctq54
    I guess not.
    Very cool though
    Congratulations Fisher
    sorry but fisher is tm of first texas.
      I try to keep Geotech non-partisan.
        The difference between an ethical professional and a hack!
          Won't be long and 3rd party coils will be out. LOL
            Not at US $2500 plus
              As a European, I would rather have seen him at XP
                "The metal detector has several search modes ? you can shift the detection of the conductivity of metals,
                for example: you can move the detection towards poorly conductive metals (small gold items)
                and at the same time eliminate highly conductive targets (large coins of silver and copper)
                and vice versa ? you can look for large targets and cut off the poorly conductive."
                (Quote from Hobby-detecting)
                So, if you go for poorly conductive small gold nuggets, you will eliminate highly conductive big nuggets too (not silver only)?
                Mean, to be sure, not to go past something, we are forced to multiple search in different modes over every terrain?
                Considering this, is claim of Ferro / NonFerro discriminating/differentiating still real?
                What producer say?
                  as always. you guys misleading Ohm conductivity with Fuko-Eddy current conductivity.
                  your school time gone beside you.
                  gold and silver (ONLY!) is POORLY conductive metals for Eddy current.
                  мы называем такие токи ВИХРЕВЫЕ ПОВЕРХНОСТНЫЕ
                    I also have seen these claims but will wait until units are out and in use before considering any opinion.
                      When I read the quote from Hobby-detecting, my conclusion was that this is conductivity-based discrimination (like White's TDI can provide by highjacking the ground balance) and not ferrous/non-ferrous. I assume this detector also includes the capability of ground balance, so maybe this a second "notch" function?
                      I guess we'll have to wait for the promised videos ...
                        Based on other forum discussions, particularly Dankowski's forum, it seems this 'first version' AQ / Manta will have a conventional mono-coil. The 'full' version, with the dual coil design, that helps negate wet-salt ground signal is presumably a work in progress.
                          What if you stop blaming yourself and instead read something in matter, before shouting nonsense?
                          "Add this all up and small gold items are low on the VDI scale and large gold items high on the scale.
                          Silver being a better conductor than gold, a silver item will read higher on the scale than the identical
                          size and shape gold item. In general silver will read higher than gold.
                          However, a very large gold item
                          can read higher than a very small silver item...
                          Quoted from here:
                          https://www.detectorprospector.com/forums/topic/3523-target-id-vdi-numbers-for-gold-nuggets-and-gold-jewelry/
                          But according you, by VDI numbers expressed targets conductivity are not related to in target induced eddy currents?
                          By your words: "your school time gone beside you.".
                            What if you stop constantly blaming yourself and instead read something in matter, before shouting nonsense?
                            " Quoted from here:
                            you will eliminate highly conductive big nuggets too (not silver only)? - WHO WROTE THIS??! BLAMING YOU?!
                            BIG NUGGET HAS MORE POORLEST CONDUCTIVITY THAN SMALL ONE!!!
                            ПРИЧЕМ ЗДЕСЬ VDI! ВОТ ЖЕ БЛ КАК ЛЕГКО ТЫ СОСКОЧИЛ С ТЕМЫ! УЧИ МАТЧАСТЬ!!
                              Vodka driven, blah, blah, blah ...
                              учиться, учиться и еще раз учиться, сказал товарищ Сталин
