During a conversation with a friend we were talking about the differences between original brand items to a Chinese copy, in this case it was the Garrett probe pointer which sells for around ?100 compared to a Chinese copy at ?15 or so. I have read that the Original brand Garrett probe pointers can have issues, not working, packing up after a few months or a year, or most working fine as normal with no problems. As with the Chinese copy's i have read similar reviews, either good or bad, in both cases.
As for Garrett its been said that the original brand probe pointers are manufactured and assembled in China as with most things, not sure if this is true or not with Garret. If so, i was wondering the differences between the Chinese copies and the Garrett brand. Apart from the casing, is it the quality of the components or the quality of the assembly work between the two. Never had the two apart on a bench before for me to examine to check both situations but my experience with Chinese electronics is that the wiring is very thin and flimsy and the soldering is much to be desired, in some cases with other Chinese made electronics just touching, a hard knock would break a wire join. To remedy such problems with such shoddy work its a matter of installing better quality wiring and a re-solder of the wiring in place and in most cases working just as good as a non Chinese copy.
What are you thoughts seeing as most brands you think are non Chinese made, turn out to be manufactured in China. Has anyone had a Garrett probe pointer and its Chinese clone apart to see the differences?
