Goldpic with 1 m coil works well
  • Goldpic with 1 m coil works well
    I post this just to let you know I was able to make the modification on Goldpic3 and put a 1m square coil on it. It works great, detecting at 1,20m deep a 60 cm target, at 80 cm a 20 cm wide target. Unfortunately I don't have a digital camera to show the material. I want especially to thank Thomas who helped me.
    Claude
    Re: Goldpic with 1 m coil works well
    Do you use cupper wire and what is the diameter? How many turns?
    Thanks Rudi
      Hi Rudy,
      I used a multi-wire 12 wire multistrand 0.25 and I inserted then soldered between them the wires, leaving two for connection.
        Hello Claude,
        Can you tell me the approximate values you have for frequency, delay time and receive time? Thanks so much.
        Darren
