VLF detector
    Re: VLF detector
    Slu4aino popadnah na foruma i mnogo se izkefih!Ima li oba4e njakvo info za glavata?
    Pozdravi!
      Re: VLF detector
      Imam vsi4ki danni no ne sa vazni dannite,samata nastrojka e po-vazna.
        Re: VLF detector
        Mnogo interesna shema.
        A imali PCB i dani za namotkite.
        Ako nee sekretna razrabotka
        bihte li migi izprateli Email: [email protected]
          Re: VLF detector
          A moje6 li da spodeli6 ka da vdigna dalbo4inata na magnuma!I dali bi rabotil s koncentri4ni bobini,eventualno broi navivki za tiah!
          Probvah da napravja ekrana na magnuma s platni navivki i tova malko pomogna ama ne dostata4no!
          I o6te ne6to - pri opisanieto za naprava na koncentri4na glava e spomenat niakav kontakten sprei?Vaprosa e s kakvo moje da se zamesti v na6te uslovia?
            Re: VLF detector
            Gospoda,vazmojno li e i az da polucha sashtite danni--za namotkite i ostanaloto.
            S uvajenie--Ben
            [email protected]
              Re: VLF detector
              Tova e vtora stranica na foruma pishi na novata za pove4e otgovori
                imas vrednosti za coil vlf seme/shema_metdet.GIF[/img][/QUOTE]
                  DALIBOR
                  Originally posted by Vladimir Minkov
                  Hi,here is a circuit,that I did before some months.Coil configuration is DD,but is usefull and concentric.If you want to check I'm sure that you will be satisfied.
                  ENGLISH
                  > Hallo my name is Dalibor
                  > Hallo
                  > Have you picture PCB and Pricel for coil for shema
                  > VLF METAL DETECTOR from Vladimir MInkov
                  > from THIS link
                  >> SERBIAN
                  >> Ako razumes srpski
                  >> Dali mozda imas vrednosti kalema za semu VLF METAL
                  >> DETECTOR od Vladimir MInkov
                  >> Sa OVOG linka
                    DALIBOR
                    ENGLISH
                    > Hallo
                    > from THIS link
                    >> SERBIAN
                    >> Ako razumes srpski
                    >> Sa OVOG linka
                    MY EMAIL
                    [email protected]
                      Hello Vladimir!
                      Have You a PCB circuit for this detector? Please, can You put it to forum?
                      Good luck
                      Satel
                        Head Coils amd Waveform Details
                        Hi Vladimir,
                        You said in November 2004:
                        Soon I'll post some instructions specialy for this circuit because head coils and wave forms have to be adjusted exactly on the right place.
                        Please can you post these details?
                        Thanks.
                          Duleeee Savicccc !!!!
                          Dalibore ne gubi vreme sa ovom igrackom !
                          Pogledaj malo bolje po forumu,naci ces bolje projekte!
                          Pozdrav...
                          za ostale...
                          Oye como va!
