I finsh my PI detector and I have proble with change of tempereture, The depth decreise with the increse of the temperature.
I'm using the OPA132 a verry good opamp with temperature and I use microcomtroller for generate the pulse and delay.
I see that the diode that limite the sign from the coil is cause the tempereture problem, I'm using the 1N4148.
Have someone had this problem ?
Do you know a good diode to use ?
Gilmar
Gilmar
