Wireless headphones
  • Wireless headphones
    Hi All,
    I posted this on the PI forum but thought it might fit here also. It is adapting a wireless headphone system to a metal detector.
    I tried a couple of different RF types and found there was to much interference to be used on a PI, so I tried the IR type. Here, I had some decent success. Originally, the best I found was the Koss HB 70 models. They worked extremly well.
    Later, I noticed that Radio Shack had their IR headphones on sale at a really good price, so I tried them also. Well, they worked as well as the Koss. In fact, the Koss headphones worked with the RS transmitter, so I suspect we can figure out who made them for RS.
    Ok, adapting is quite simple, one simply needs to build a simple power supply for the transmitter. The signal will come from the heaphone jack. Now, for a battery, I used a surplus 7.2V Li Ion battery I purchased from a surplus house. Then I simply attached a coax plug compatible with the power supply so I could use the battery instead of the wall wart supply.
    When done, the project worked far better than expected.
    Now, for your doit yourselfers, there is a schematic on the net for an IR transmitter and receiver circuit. However, I doubt one could build one for much less than the price of the Radio Shack's setup.
    Reg
    Re: Wireless headphones
    Reg,
    Where is the IR schematic posted? I am interested in seeing it. Also, are the IR headphones stereo or mono? Dave. * * *
      Hi Dave,
      Sorry Dave, there are no schematics on this project. The concept of this post is more of a simple buy and use system, rather than a design and build. The only real mod necessary is to provide dc for the transmitter, since 120V outlets are rather scarce out in the field, and that can be done using a simple battery with the appropriate plug. Otherwise, it simply uses off the shelf items.
      The main objective of this post was to provide info to those who might want to use wireless headphones to avoid cable hang up problems in brushy areas but don't want to have to spend a tremendous amount of time or money to develop a setup to do it. It should have appeal to the relic and nugget hunters.
      The headphones used are stereo types, or appear to be. I have only used them on my metal detectors, so I can't say for sure.
      For those interesting in trying to build something from scratch, there are a few schematics to be found on the net. Once can do a search for IR transmitters and receievers and should come up with a few basic designs.
      Reg
        Reg,
        I thought you had a specific schematic in mind. I have been playing about with an IR transmitter and receiver which I based on an old IR project that I designed many years ago. I will update you as soon as I test it outdoors. My system is mono only which should be OK for most detectors although I believe that Nautilus detectors use a stereo output with the tone for all metal on one side of the headphones and the discrimination signal. I bought the Radio Shack headphones today and I was really surprised by how good looking they are. The price is way too low to put off buying them. Thanks for letting us know that they are on special offer.
