Sean, They are also the same people that buy that damn bracelet. As they say "a fool and his money are soon parted."
Radar a long distance gold detector
Originally posted by KlaudIf you find something with GPR (futuregpr ) let me know how !
I have one Future 2003-2004 Grail, useless. That's a fake !
I have try one full year with it and althrough I am computer engineer, I can not get consistant results on known targets.
ZOND-C for instance is a true GPR.
A GPR can look in ground under it but not few meter ahead.
Now I use Syscal, resistivitymeter TR/CIA and gradiometer.
I confirm with a Deeper8.
Hi, thanks to share your experiments. Maybe the I-160 seems to be better.
http://www.schatzsuchermagazin.de
Future of OKM is not a GPR!
It´s a magnometer!
Inside is a KMY-10 Radar-Sensor. It cannot work´s with this frequency into the earth!
OKM cheat´s the people!
Put Future and OKM to the garbage pail!
Ask the user´s of future in Greece!
OKM pray-reprimands the people! I can also prove it!
I cannot hear it any longer
Can you send me a schematic of som lrs detector?Originally posted by KlaudIf you find something with GPR (futuregpr ) let me know how !
[email protected]
Im also intersted w/schematic diagram. thanks leonardoOriginally posted by GeoPlease can you send me the shematic? Thanks
[email protected]
i also interseted, can u send me the schematic diagram? tqOriginally posted by Unregistered View PostHALLO
[email protected]
BAROSSOV
I BUILD GRAUND SCANER OMNISCOP.
IF YOU HAVE INTEREST I CAN SEND THE SHEMATIC
DIAGRAM.
[email protected]
Arr Arr
Having the schematic and building the device are not enough. You must also BELIEVE!
BE-LEEVE in LRL and you may DOW-OW-OWS YOUR way into RICHNESS and the blessings of, JIN DOW-SEE.
I heard that L. Ron Hubbard wrote a fiction book and started a new religion. Made Millions of $$.
Gold radar Gun
im so sorry i forgot to write my mail...here is [email protected] and tell me man if it work well...? thanks again
Originally posted by Fernando View PostBrothers,
What do you suggest for the best detecting equipment for a 9 meters deep of treasure. Have used the GPL ( Ground Penetrating Locator same as Accumeter Pro V as published in Accuratelocators.com ) already and it identifies 8 meters deep but the problem wiht the device is it can pinpoint the exact loacation of the item. Somehow I believe the GPL did not lied to me by indicating the gold presence in my site but it has the difficulty in determining the exact location. What other equipment should I use to pin point my target?
Can a new pinpointing device made by USA as published do the job?
Catipillar D9T should do the trick
http://www.cat.com/cmms/13873485?x=7
cheers
Yeah! Remove the ground "big time", spread the material around 30cm thick over the floor and search the stuff with your MD.
But another question:
The OKM Bionic 01 now really exists already for 5 years?!
If I should interpret post #11 here correct:
http://www.geotech1.com/forums/showp...5&postcount=11
After such a long time it should be shure if, how or if it doesn't work including serious test reports, blind tests in the field and electronical reverse ingeneering. So what's the actual status quo ??????
I would suggest that you use the Cat D9 to dig a hole 9 metres deep and then place the OKM Bionic 01 into the hole and fill it in and then see if any of its mates can find it
Incidentally a friend is heading over to Germany shortly and he might go and check out the OKM mob if he gets time. I told him not to buy anything under any circumstances as any company that sells LRL witch-craft machines could not be trusted
cheers
Steve D
Or your friend could create a dowsing rod made out of gold and check if it finds the OKM factory!
But wait with your judgment - this is not so simple as it may looks. They simple can't sell stuff for a huge amount of 10.000 bucks that does not work - they will detect swedish curtains if they do.
btw. what the hack should motivate electronic engineers creating useless and worthless crap?!
So the question is under what circumstances it detects whats-o-ever and how the electronical circuits really works!
It is good if this forum is very critical but that cannot go into the "all LRL always are pure sh**-direction".
Probable I also will visit the "OKM-plant" near Leipzig this summer for checking out how much worth those Bionic devices really are. Not forget the rest of their computer-supported "ground-radars" really work (but are way too expensive)! They won't ruin their reputation completly with not working "witch-craft or placebo devices".
Comes time, comes information...
I'll think you'll find that they can. As Einstein is reputed to have said, "Two things are infinite: the universe and human stupidity; and I'm not sure about the universe".Originally posted by Funfinder View PostBut wait with your judgment - this is not so simple as it may looks. They simple can't sell stuff for a huge amount of 10.000 bucks that does not work - they will detect swedish curtains if they do.
Originally posted by Funfinder View Postbtw. what the hack should motivate electronic engineers creating useless and worthless crap?!
The answer is obvious ... a quick buck!
