I am new to the pic16f84a. I use mplab as my debugger and am not sure of all the errors. If anyone has anything on them I would appreciate it if you could post a link. Thankyou. The problem I am having is when I insert the shift register command and compile I get error messages that say the overwriting the previous address. If anyone can help me with what I am doing wrong it would make my day.
LIST P=16F84a ;tells which processor is used
INCLUDE "p16f84a.inc" ;defines various registers etc. Look it over.
RA4 EQU H'0004'
RP0 EQU H'0005'
STATUS EQU H'0003'
PORTA EQU H'0005'
PORTB EQU H'0006'
TRISA EQU H'0085'
TRISB EQU H'0086'
CLRF PORTA ;Initialize PORTA by clearing output data latches
BSF STATUS, RP0 ;Select Bank 1
MOVLW 0x0F ;Value used to initialize data direction
MOVWF TRISA ;Set RA<3:0> as inputs, R4 as output, TRISA<7:5> are ;always read as '0'
ORG H'0000'
BSF STATUS, RP0
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F84A "final.asm" /l"final.lst" /e"final.err"
Message[302] C:\DOCUMENTS AND SETTINGS\CHAD\MY DOCUMENTS\FINAL.ASM 14 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[118] C:\DOCUMENTS AND SETTINGS\CHAD\MY DOCUMENTS\FINAL.ASM 16 : Overwriting previous address contents (0000)
Error[129] C:\DOCUMENTS AND SETTINGS\CHAD\MY DOCUMENTS\FINAL.ASM 20 : Expected (END)
Halting build on first failure as requested.
BUILD FAILED: Thu Sep 08 16:17:50 2005
Ultimately what I am wanting to do is make a counter that automatically incrimates when a clock pulse is sent to it. We are controlling the clock pulse maunally. After we push a button, the counter will automtically incrimate. Thanks lots.
RA4 EQU H'0004'
RP0 EQU H'0005'
STATUS EQU H'0003'
PORTA EQU H'0005'
PORTB EQU H'0006'
TRISA EQU H'0085'
TRISB EQU H'0086'
ORG H'0000'
BSF STATUS, RP0
Clean: Done.
