2 boxxxx :)
  • Originally posted by Hisoka View Post
    I really thank you Gary(chemelec) for ca3035 circuit I have been looking for it for long time.
    you seem to be forgot the 1uf capacitor which connected to headphones and the earth
    I tried to connect them in the circuit you made as shown in the attachment:
    [ATTACH]16181[/ATTACH]
    please check it
    And can I really use it with the transmitter circuit made by Charles D. Rakes:
    [ATTACH]16182[/ATTACH]
    And I can not see this project on your website, please give me it's name
    No I Never added that Cap on the Schematic or PCB I Designed.
    I put it on seperate.
    My Circuit Works very good as a Replacement, So make it and try it.
    I DID NOT Like the Final Results of that Detector, So I Removed it from my website.
    • Originally posted by chemelec View Post
      thanks a lot dear chemelec
      can you post some test result here? i was built it it some month ago and it work, but i leave it because i went to make some LRL, so if you can post some test and say to us what is detection depth for a car , it will be useful for me!.
      thanks in advance
      mehdi
      • Sorry, I built that 2 box detector, quite a few YEARS Ago. Can't remember the Results now.
        But I Was Not impessed with it, And Threw it out.
        However, My Transistor Version of the CA3035 does work good.
        • two box
          Thank you agian Gary(chemelec) but can I use the transmitter circuit made by Charles D. Rakes as I posted previously
          can I also replace the 2n2924 in the transmitter circuit with BC183 ?
          Did you mean that you never used that capacitor in your circuit ?
          Please check this circuit if everything correct after I removed that capacitor :
          [ATTACH]16190[/ATTACH]
          Please What would you suggest as good sensitivity detector and can be home made.
          • sorry for mistakes in quote in previously post
            • Friends can any one explain these symbols:
              6-32
              6-13/16"
              2-1/2" 8-32 screw
              in following picture:
              • 6-32
                6-13/16"
                2-1/2" 8-32 screw
                They are USA Screw sizes in inches.
                  ok, thanks for answer.
                    [ATTACH]16191[/ATTACH]
                    Hi
                    i was built this schematic and pcb for transmitter and i used 2N2646 instead of 2N4870 and it work good
                    all the best
                    mehdi
                    • sizes of the box
                      6-32
                      6-13/16"
                      2-1/2" 8-32 screw
                      But the hight of the box is 2-5/16" , I know it's in inches, but really I don't understand it.
                      Please Gary can you explain it.
                        HISOKA, DEAR FRIEND. what language is your Native? what country you are from? China? Japan? Madagaskar Island? WHAT?
                        • Hello, kt315
                          I am from Syria
                          • two box sizes
                            Hello friends
                            Does 2-5/16" mean 2,3125 inches ?
                            • Friend mehdi, from where did you get this tranmitter circuit, I think the orginal is this:
Name:	Tranmitter schematic.jpg
                                Hello friends
                                Yes, but you should use point instead comma. The comma in English means 23125 inches
