I have been constructing the HH, and have reached a point where I have a few questions that may have answers that will help others. Most may seem pretty simple, but maybe I am not alone with these difficulties. Anyway, I figure others may benefit too from this. Here are my questions.
When everyone talks about delay times before the first sampling for a fast coil. Is the correct measure of the delay time for a coil the time from the end of the TX pulse to the zero point on the flyback pulse? Should I be trying to reduce the time between the switch off of TX and the start of the flyback pulse? It currently is about 5 usec. How is this done? Should I adjust the Tx pulse width to reduce the width of the flyback pulse?, or should build a different coil?
How do I use the measured resonance frequency of a coil to calculate its inductance in microHenries?
On a scope I can see a change in the output at TP9, but this does not register as anything coming from the speaker. Is this to do with the threshold voltage setting? I only get a sound out of the speaker/headphones if the signal saturates at TP9 (hits the ceiling).
In the construction and calibration section of Carl's paper on the HH it says that the output from the NE5534AP should be adjusted with R18 to be 0.0. Why is this done?
I have used 30 micron Al foil for a shield and could see no effect from this? How do I know if my foil shield is working correctly?
Is there such a thing as ground balance for PI like the HH?
Well, enough of my ramblings.
I would like to thank Carl. The HH is a brilliant learning tool, and I have enjoyed every moment working on it.
