Coin shooters schematics
  • Coin shooters schematics
    Hi, everybody...
    Let's post here schematics of coinshooters metal detectors. Is there any good
    schematic for metal detector, whit which U can easy locate only coins, and discriminate other metals. I do have only White's coinmaster schematic.If somebody is interested I can post it here. I also looking for the other schematics of this type.
    Regards!
    hi,
    i buyed coinmaster 6000/D, but it doesn't work good. The coil cable was not good and I changed it (the coil was already opened), but the detector works only on "TR Disc" position and the ground ballance is also not working. I think I need your help)) please post the schem...probably i could find the problem easily.
    10x in advance.
    [email protected]
      I think this machine has two circuit boards inside it. Take the blue box apart and make sure thetwo boards are pushed together properly. If it stil doesnt work, then clean the connections with isopropyl alchohol. If this does not cure the problem, it may be the mode selection switch or possibly something more fatal. Whites will sell you the manual for old detectors such as this, so you might like to try them for help too.
        there is only 1 PCB inside.
          Oh, I''m thinking of the 6000Di .your machine is even older. Try Whites in the UK, they are very helpful. Sorry my suggestion was no good.
            Coinshooter
            The same Coinshooter by William Lahr? This projrct is in pages of Geotech:
              no. it is not the same.
              Please write replies in my topic http://thunting.com/geotech/forums/s...d.php4?t=11453
              because we are spamming here , or PM
                Hi
                Maybe this help U.
                Regards!
                  Part II
                  Cose of size of file i split it on 2 parts...
                    thanks!!!
