Just about every P.I has the input signal rammed up the input of a super low noise opamp. This is usually fed via a 1 or 2K resistor with a couple of 1n4148 dides acting as a clamp staight into the input of the opamp.
Guy's there has to be a better way as this is 1960's technology.
I have made a small improvement by clamping the back emf from the coil via a 270 ohm resistor shunted into an 18 volt zener, the output of this then goes via another 270 ohm R across the clamp diodes into the opamp.
I used an 18 volt zener as I just happened to have a few lying around.
My thoughts on the matter are red hot limiting resistors generating thermal noise. All diode clamps add capacitance to the circuit. Has anybody experimented with a syncronised fet shorting the input while the TX stage is firing? What about transformer coupling? There must be some bright sparks that have previously looked at this problem. Any thoughts on this most appreciated.
