Esteban is right... when you put the coins in a metal container, it is only the container that gets detected. Here in the US, where caches are typically 50-150 years old, a popular container is a glass mason jar, which might have a zinc lid, or might have a glass lid with wire bail. So my preference is to continue the test, assuming that the container has no appreciable metal.
- Carl
Hi Carl. Good test for America but bad for Europe where there are caches 50..2500 years ago inside metallic boxes. Anyway every test is wellcome.
But a metallic box 2000 years ago inside the ground can more easy detecting than in air.
Carl, How about doing a variation of the test but this time bury the coins in an iron pot, Coffee can, etc but keep the size about the same size of the plastic tub that you used. Also do the same but use a Glass mason jar with a zinc lid. Keep all the parameters the same as Gary's test. I plan to do the same....Also I plan to keep the site watered and will report on the results. May take a week or so to get started as I'm leaving on vacation today for a week.
The theme is to detect disperse coins, no in jar or coffee can, etc., these recipients are solid body. Detection of sparse coins is a hard business!!!
Guest replied
Halo
I've large plastic containers with gold, silver, copper and other coins. Some are over fifteen years old now.
Gold gives no halo effect, pure silver none...in fact the black patina seems to cut detection depth. Same with pure copper as it creates a patina and becomes as one with the soil.
Alloyed coins do give a better response as one of the metals leeches out. (subject to the soil being damp). A 1921 to 1947 British 'silver' coin (50% silver,50% copper) may look perfect but can lose half its weight and be snapped like a carrot.
The poorer the metal used in a coil the faster the breakdown and the deeper the depth of detection but the coin will hardly be worth digging due to the poor condition.
Dry out an area (leave container in a water proof outbuilding over a summer) and the chemical reaction slows or stops.
This leads me to conclude that the improvement in detection depth on alloyed metals is due to the breakdown generating a small current for which dampness/wet is required ie a combination of the well known fact that its better to detect in damp soil and the Compass Depth doubler principle.
Carl, For this test,I plan to use a Garrett BFO with the large 12 by 24 inch and 24 by 24 inch coil, a Garrett Deepseeker with 15 inch coil, and a D-Tex Search King with the 15 inch coil. That's about the extent of my deepseekers for most of my machines are for coinshooting!!
Joe, a number of people have looked into the "halo" theory, and I think it's close to being busted. Gold absolutely does not create a halo, and silver and copper probably do not, either. Yes, they corrode, and they probably leech some atoms into the surrounding soil, but this does not increase the eddy current response. Iron is another story, and it does produce a halo effect.
I have an experiment on halo effect planned for this summer, starting next week, actually. Should be interesting.
- Carl
That would be a very interesting experiment indeed.
Many years ago, using a simple IB machine, I detected a George III copper coin from 1797. These coins were known as Matthew Boulton's "Cartwheels", and were some of the first copper coins produced in the new fangled steam press. Its diameter is 35cm and is 3mm thick. This coin was detected at a depth of 11", which was pushing it somewhat for this particular machine. In fact, I almost gave up digging, and then "voila" - there it was at the bottom of the hole! Once removed from the hole, the same detector could only manage to detect this coin at a distance of 9". This is contrary to expectation, as all detectors can achieve better detection distances in air than in the field. Also, this is not the only example I have enountered over the years. So - is this caused by the halo effect?
Carl - hopefully you won't need to wait 200 years for the halo to occur.
That's pretty cool. I've never even doubted or thought twice about the halo effect, but what Carl is saying makes sense. As Carl said, Iron produces halo effect. That makes sense because iron is a magnetic material. If you have a 1" square piece of magnetic material, and say at 3 feet away it produces a returned signal of 8 units. Now if you break that square into 3 x 3 x 3 (27 chunks) and appreciably separate the pieces you should get a returned signal close to 8. That's how proportionally square magnetic materials work; i.e., not much change in *effective* permeability. Ferrite rods is an entirely different story because a change in length versus radius changes the effective permeability.
Eddy currents in electrical materials greatly depends on material size. So if you break a square chunk of copper into 27 pieces then you decrease the eddy currents by magnitudes. So I can't see spread out atoms of gold or copper producing any noticeable halo effect, but I guess anything's possible.
And, I also have a Garrett BFO with both the 12x24 and the 24x24 coils... I'll give it a try.
The problem with Gary's test is that no time has been given for the halo effect. Silver Coins buried for 100's or 1000's of years should have a tremendous hallow effect especialy if the container was iron or brass,etc. But even if the silver coins are buried in a ceramic type of container the silver would leach and hallow out! This test must be an ongoing one to test every 6 months or so. But after 6 months to a year I bet that I could locate that cache with my Garrett BFO discriminator with the 12 by 24 inch or 24 inch magnified coil or with a pulse Induction detector with a very large coil. Another note is that the plastic tub may not let the coins hallow out at all.. ANCIENT CONATAINERS WERE NOT WATERPROOF....Maybe you need to poke a few holes in that tub!!??? Just my knowledge of 35 plus years poking around for treasures!
You know, while having new tires put on the car yesterday I was scrounging around for lead tire weights. I found one, but it sure don't look like lead. I'm wondering if they're using some cheap substitute now days.
I don't know how lead compares to gold, but you're right gold is expensive. You could try tossing a jar full of tire weights, without the steel hooks.
True, but I believe all of Gary's tests were with discriminating VLFs... in fact, he specifically said he would not test a non-disc detector, because such a beast would be unusable in England's iron-laden fields.
But I still think PI's should be tested, to see if any will pass the test. They would be useful in many other cache-hunting scenarios. A better PI test would be to bury 3 pounds of gold coins... alas, I'm a tad shy of that mark.
I decided to roughly match Gary's setup... he buried 1kg (2.2 pounds) of coins, copper & silver mixed, about 25-inches deep. I chose 3-pounds (220-count) of silver US quarters. This gives me an edge... a bigger cache, and all-silver so it has higher conductivity.
I would have to disagree with that. I believe that a PI can take advantage of the fact that lower conducting materials has a faster di/dt decay time, which means higher voltage. Remember that the increase in the coin/nugget's eddy current will be about the same regardless the metal type, to within reason, because the pulse should be fast, meaning it's mostly inductive, not resistive. But when the applied voltage is removed then the coin/nugget will decay at a rate depending on the resistance of the metal.
Well, that's just PI and nothing to do with VLF's, and that's assuming the PI is tuned for the lower conducting metals such as natural gold, not coins.
Hole is covered. I'm seriously concerned that when the grass recovers, I may never be able to find my coins again. I need to add some method of marking the spot.
