Cache Test
hello friends, i want to do another test with a collection of silver coins
-how deep is better to do?
-what is the best container?
Uploaded with ImageShack.us
the coin is .500 silver, i have 2.500 coins.http://en.numista.com/catalogue/pieces8320.html
Hello friends! I forget tell one thing., I miss is that in the place of burial there is more moisture, maybe Carl and the others are missing or need it.
Emfad UG12 is not a LRL. It works only for very very big objects as a barrel etc and only when the device is up to the object.
Hello Forum, Yes my test isnt deep, is about 2kg, my container are 14cm x 14cm and put in hole about 50cm underground (bottom container) in relation about this topic.
And I think the gold gun is more cientific instrument (long range locators) I have a silver cache (about 20kg) and I want put in my (garden 16m x 16m) in center but underground for test gun and my other detectors, someone know what deep is better?
Also I want find a real gold cache,,, I believe here in Mexico are something. I know the old site, and there one revolution man put he larkspurs in rock fence in 1910, my friend find larkspurs in 1960. I think the gold are in that site or near but undergrond, I need first a cientific long range locator for check/test, but I need money to buy a really long lange locator...
I think this long range locators are cientific: Magnacast5000, EM16, emfad UG12, am I wrong?
Thx for the test. How deep was it and what is the size / metal of the container?Originally posted by Agraz View PostHello aft_72005. And People.
PI hammerhead 1mx1m Carl M.: YES
Magnetometer Carl M.: YES (some difficult)
Mineoro 2006: NOT
Gold Gun Al707: NOT
More =?
btw. did you ever really found something just with the Mineoro or Gold Gun?
Hi Agraz,Originally posted by Agraz View PostHello aft_72005. And People.
Sorry I’m late. Is old only the container, isn't the coins are nickel, cooper, etc., but coins was underground since 1997.
And in 2002 put in ground again in old container.
This is the result in 2011:
Magnum force f., whites 2009 sierra madre: YES detection
And others detectors, two box: YES (only with extension cord)
Mineoro 2006: NOT
Resistivity survey: NOT
Gold Gun Al707: NOT
3 Metal detectors (with normal coils) NOT
I want wait more time,,, for again using detectors for test, also I want put underground many silver coins: (Ley 0.720 , 0.500)
1 coin = 1" Relic mode = 35cm -Max 50cm
50 coins =?
More =?
I looked back at your previous post, but could not see what weight of coins you used for the cache. Also, you state you buried the coins at 20". Was the 20" to the top of the container or the bottom? Note the original cache test was 2kg buried at 24" to the top of the container.
Mineoro 2006: NOT
Gold Gun Al707: NOT
50 coins =?
More =?
Hi auminesweeper!Originally posted by auminesweeper View PostG Day Funfinder, well heres the Air test Results that you asked for and I hope this is of use,
Please note that the lower measurements are diggable signals and the Max figures
are the maximum using the Third tone
1) 1 coin = 1" Relic mode = 35cm =14" 3/16, Max 50cm = 19" 11/16
2) 4 coins = 2" square Relic mode Dig 47cm = 18"1/2, Max = 57cm = 22"7/16
Prospect mode 56cm = 22"1/16, Max = 64cm = 25"3/16
3) 9 coins = 3" square Relic mode 56cm = 22"1/16, Max = 78cm = 30"1/16
Prospect mode not done.
4) 16 coins = 4" square Prospect mode dig at 800cm = 31"1/2, Max 900cm = 35"7/16
5) 25 coins = 5" square Relic mode dig 72cm = 28"3/8, Max 85cm = 33"7/16
Propect mode dig 90cm = 35"3/8, Max 100cm = 39"3/8
6) 36 coins = 6" square Relic mode dig 75cm = 31"1/2, Max 92cm = 36"3/16, please note I got VDIs at 60cm=23"5/8 to 64cm=25"3/16 in relic
Prospect mode dig 95cm = 37"3/8, Max 105cm = 41"5/16.
My next tests will be Burried tests in Med/High mineralization ground,
I hope this helps,
John
Thanx for making an not forgetting that test.
This is very good result and it shows the coins don't need to have any contacts inbetween them and only the 2 dimensional size of the metal counts and not how thick it is.
Now we look forward to your tests with buried coins and please compare the difference if depth results in all metal mode and with discrimination on.
Good luck!
The Nexus Ultima 5F is probably your only hope.Originally posted by frankhunter View Posti am really confused about what brand and model will help me in treasure hunting , here some information about the field ,there is rocks salt and rich mineral soil .
am searching in 2.5-4 meter depth .
target is not less than 5 kilograms of old made gold coins ,- no raw gold or nuggets at all- .
my target is 100 years old buried inside wooden box or a jar
might be thin made layers of charcoal and sand on top of the target
i need fast accurate reading while scanning underneath . (imaginary devise)
i need a devise to eliminate searching area tells me that my target will be around 500 square meter or less .
thank you all
we know that in all things god works for
the good of those who love him
Its great the only ansewer I get and its a yama treasure seeker
Lifes tough at the top, Mighty Impressive
i need help
thank you all
Just to correct my last post, It was not the MXT Pro, IT WAS the MXT 300
with the standard 300 coil, sorry about that,
John
are the maximum using the Third tone that my machine uses to alert you of the items
pressents, Doing these tests I used the standard coil that the machine came supplied
with and with the gain at maximum in the Relic mode and in the Prospect mode the gain
was set at +1, the Machine I used is the Whites MXT Pro fitted with the standard 12"
concentric coil as supplied with the unit,
These coins were stuck with double sided tape to a sheet of 1/4 plywood board
and a 3rd of the way through the test i decided to use a hot glue gun because
it is quicker and when you want to take the coins off the board the glue will
stick to the board and not your coins so there is no need to clean the coins
afterwards.
The Max distance is just audiable in the third tone threshold based signal,
and the coins were glued flat in a square each time adding enough coins
to keep the pattern square, Due to EMI and the time was around 17.30/5.30pm
using the prospect mode I could not turn it up to +3(Maximum) and so +1
was the highest i could set the machine,
I hope this helps,
John
