Cache Test
  • Carl-NC
    I disagree... only because, so far, nothing at all will detect the cache, at least in my case (I don't have a Nexus). So my goal is to find something that will detect it, whether VLF or PI or BFO, regardless of coil size, or operating mode.
  • Unregistered
    Guest replied
    Originally posted by hung
    Esteban,
    If you have the 08MI or MP10 2 boxes units by Mineoro, try this cache test. I believe they will easily pick this up. Actually 2 meters down would be a fair test for them. Specially for the silver cache. Pay attention to the small objects VU. It's got a tremendous sensitivity.
    In 1969 with one of those, Mr. Anisio Trelha found a cache of gold coins from 120 m away. Since the long time buried target has an intense electric field around it , this triggered the auto mode in the detector and the VU led him to the direction over the target.
    Unfortunately I don't have my 08MI anymore. If for some reason you cannot do this test, I'll ask my friend Celi who's got an MP10.
    AFAIK the Mineoro's 2 boxes are one step above anyting I know.
    I think we are missing the point here.
    The cashe test in garysdetecting was done with induction balance detector.
    Now comparing induction balance against PI or LRL or any other is like star ship to a bull wagon.
    It might be better to just run comarison between detectors build on the same principals and close phisical sizes for the search coils.
  • Unregistered
    Guest replied
    Originally posted by Unregistered
    Don't write off the Saxon due to an old Arado not being up to spec. The quoted in soil range on a Sovereign was 11 inches for the 120 (its about the size of a U.S. 5 cents). You could certainly dig old copper pennies at 12 inches+ and the 130 model was deeper again so start adding 50% and you get repectable coin depths and the larger coil on the Saxon would favour larger objects like the silver bar and cache.
    Personal opinions dont have much in common with science. Good measurement test will determine how deep is the Saxon indeed. If the Arado can find coin at 12"+ then the Saxon should get them at 18"+(50% more depth)
    Well that claim is against the laws of phisycs. And by the way the Arado does not have big enough search coil to get to that depth.
    Another fact. The Arado comes with 8"-10" coil as far as I am aware. The Saxon with 12". The difference between 8" and 12" is 50% which suggest that the difference in sencitivity will not exeed 25% (not 50% as they say)
    I believe the claims about the Saxon are not based on real facts.
    If someone pay 1700£ it will be hard to admit that it was not worted.
  • hung
    Esteban,
  • Unregistered
    Guest replied
  • Unregistered
    Guest replied
    Originally posted by wyndham
    A thought on the test. Test in a canvas bag because this is as close to not having a barrier. Since the "tupperware" is a polycarbonate, could it work as a shield or insulator at this depth.
    The other question is about the PI eddy current, does the current dissiapate into the mass or take longer than the rx can be set to?
    Just a left field thought, Wyndham
    Polycarbonate materials do not have electrical conductivity capabilities, magnetic or paramagnetic.
    Therefore they can not act as shield.
  • wyndham
  • Unregistered
    Guest replied
    Originally posted by Carl-NC
    Got out the other day with the Arado 120B... nada.
    I'm starting to bench test the detectors as well. I replicated the cache with another 220 silver quarters, wrapped up tight in a plastic bag. Also have a single 20-ounce solid silver bar.
    The Arado gives a repeatable signal on the silver bar at 11" (13" on the meter) and the cache at about 13". A single quarter is 7.5".
    I tested the Teknetics T2 and in disc mode it hits a quarter at 10", the bar at 14", and the cache at 15". In A/M mode it hits the cache at 22", which means it is just missing the buried cache.
    - Carl
    So if the Arado 120B can get the cache only at 13" in air then the Saxon X1 Ultra Depth will get them at 19.5" or perhaps 20" also in air (providing it realy got 50% more than the Arado as some say about it)
    It seem that the mighty Saxon is not that powerful then.
  • Unregistered
    Guest replied
    Originally posted by sony
    "1. The coins you show on the picture are in very good condition and very likely will be in
    good electrical contact.In a hoard burrien for long time (centuries) in the ground all
    og the coins are covered by thin layer of oxide which isolates them from one another.
    For this reason they can not be picked up as one big piece of metal...."
    Yes,on the first view your statement is very logic.....but not true! I can put any bet on
    fact that long time burried coins are much easilly detected than "fresh" ones..
    It has nothing to do with "good electrical contact" at all. By the time mass of coins in the
    ground develop some sort of "echo" or some kind of field (some claimed ionic field-although
    i can not prove that to myself yet), and radius of that field or "echo" is growing more and
    more as time goes by....In a 1000 years (for example) that field would overcome twice or even
    more than physical size of coin....So you can very easy detect that mass by detecting upper
    boundary of the developed field...What kind field is that? I do not know,only i am sure that
    it need a lot of time to develop,also not to suffer any major disturbance in its nearby...
    More time passes - less difference between types of metal !? Very odd claim but true!
    On roman sites its been noted many times that proper detector could not distinguish which
    type of metal is detected, no matter of very good disc. it has...Many times excell machines
    like top Minelab or Fisher models simply confused old roman arrow (Fe) with old roman coin(Ag).
    ......!!!!???? But level of detection remains good on both(loud and clear).
    Present coins,Carl trying to detect are mostly "fresh",clean, new...It will take months, more
    likely years they to develop at least some field around. So no profit from that kind of testing
    much....But there must be way how to make those coins became "old", maybe perfuse them with
    some diluted acid...maybe peroxide....who knows? Point should be how to make artifical field
    mimic of natural one. All test with chemistry should perform on the spot, in the hole filled
    with coins.After that fast cover with the rest of soil and let it stay for a while - month or
    two....than perform tests again. Another note, coins should be mixed by types, a few of brass,
    a few nickels, a few Au...Ag..Al...Cu.... Testing machines only on Ag coins should not give
    real picture of its abillities...
    I can not simply beleive that none of Carl's detectors can detect mass of coins on that depth!?
    Something must be wrong in that soil!? But....
    It will need not only one "spot"-hole with coins, but a few of them with all combinations and
    mixtures of coins and at various depths, enough to establish at least some opinon and conclusion
    on that subject...
    good luck with that!
    P.S.
    Posted picture present 2570 Au roman coins founded in Trier....once....
    Nice try, but no science behind this.
    If you get some very old coins from a freshly found hoard try to measure the electrical resistance without scratching the patina.
    Then try this theory again.
    Also metal detectors are not capable to "see" large (thick) metal objects, but only the largest Eddy current circuit a metal object can create.
  • Unregistered
    Guest replied
    JC1
    So how do the PI s do?
    Please don't tell me they won't find
    it either.
  • Unregistered
    Guest replied
    JC1
    This really is interesting.
    That much silver.
    Oh well, and to think of all the buried
    cache chasing that has been done with
    these things.
  • Carl-NC
    - Carl
  • Lost in NC
    i use a soverign GT i run in disc mode with disc and notch set at zero. i can detect ferrous targets fairly deep lets somtimes say 10 inches depending on size. alwlays reads as a good target large iron does with the bbs from my experiance. i wonder if these coins were buried in a jar with a metal lid facing up or a mason jar with a lid or just the wire bail if over several years the result would be different . you know give the halo time to build up or maybe saturate the ground with some water see if it changes the dynamic of the test. if this test is as good as these detectors get then maybe the big companies may want to rethink the claims they make. i can (obvioulsy) find septic tanks with my two box even makes my 10 inch coil a little agitated. so i think time and moisture play a major part in caches beign found with a detector. just my opinion
  • Unregistered
    Guest replied
    Here is a photo of the first round of detectors I tried. All failed. I had high hopes for that 24" coil on the 6000/pro.
    White's 6000/di Pro with 15" coil
    White's 6000/di Pro with 24" Magnum "cache" coil
    Fisher Gemini 3
    Discovery TF900
    Minelab 2200/d with 18" mono coil
    Garrett GTI2500 with Bloodhound attachment
    Teknetics T2
    Awe come on, Carl,.....You forgot your LRL!!! (Just kidding)
    Really, though, I am sure you could call up Dell and borrow one!!!
    They work really great when you know where the cache is!!
    Dan.
  • sony
    Guest replied
    Maybe some ideas?
    on that subject...
    P.S.
