Help for Anker SS60
  • Help for Anker SS60
    Hi. I began the manufacture of Anker SS-60 in a general use pcb. My free time is minimum thus I will need at least one month in order to finish the manufacture. Up to then I would want your help for the power suply of IC's . To a collation with anker50 I led in below.
    DA1 + 9v, -12v (gnd).
    DA2 + U, -U.
    DA3??? Help.
    DA4 + U, -U.
    DA6..DA7 + U, -U.
    DA8,,DA9,DA11,DA12…? Help.
    DA10 + 2E, -2E.
    DA13 + U, gnd (-12V)
    And something still. In the place of 157YD2 who IC I can use??
    Best Regards
    157ud2 low noise 2 in 1 preamps bipolar input, 30ma max out
    DA3-1401ud3 - LM146, LF444
    DA8 - 561KT3 CD4066A, CD4066B
    DA11,DA12 - LM224N
      DA11,DA12 - LM224N
      Hi. I know the other similar IC's but i don't know the power supply of them (+U. +2E, +9v etc).:confused:
      LM339 is OK for 157UD2???
      And something else.. At SS60 schematic what does it write at the right of the page about DA3 , DA4 and R82K????:confused: :confused:
      I can not copy it from schematic and peste it at Systran...
        power supply
        u can use 7805 (+2E,+U) 7809 (+9V)
        >LM339 is OK for 157UD2??? i dont know too, required to shake two transistors average capacity
        pin 8 and pin 9 DA3, DA4 connected GND through 82K
        http://anker50.narod.ru/a_ss60.htm
        http://forum.md4u.ru/viewforum.php?f...bdd8aa677dbdc1
          only DA10 is with +-2e
          all others +- U
          dont make this - very unstable in ground - no GEB, sound in every stone and soil imposibble ballance - very big TX signal reflecting from soil
          very good in air no usable in soil
          make Tunder
            Hi Golum.
            Likely I did not give you occupy :confused: what I ask. In the drawing of Anker-SS60 exists the following tendencies. + 12v, + U, + 2E, - U, -2E, -12V (gnd).
            I want to learn with what volts to supply the DA3, DA8, DA9, DA11, DA12:confused: .
            For LM339 i mean LM393.
            Regards.
              all others +- U
              make Tunder
              Hi Tunder. I made about the half .
              What is the Tunder??:confused:
                [quote=Geo] Hi Golum.
                see http://anker50.narod.ru/a_50_opisanie.htm
                + 2E, -2E feed of synchronous detectors
                  [quote=Golum]
                  Originally posted by Geo
                  Hi Golum.
                  Hi. Rumensat says that SS60 is a unstable detector. What do you know about it ??
                    HI!
                    SS -60 has shown the excellent results on air ( the coin by diameter 25мм registered with distances 60 refer to), scheme worked stable. However, appeared the difficulties with compensation of the soil - possible, power agitating field turned out to be too much. To reduce her(it), it is enough to disconnect the half agitating bridge. The Best using given schemes - a work in "light" soil (sand, snow).
                      Yes but when disconnect the half agitating bridge distance go to 45 sm. in air, which is reach with many simplest detectors.
                      dont forget that this schematic has a lot of parts.
                      But in Tunder has some mistake with GEB - when adjust P1 you change balance of the coil in the same time.
                        Originally posted by Anker
                        HI!
                        Hi Anker. Do you mean to make the transmitter of Anker-50 ??.
                        Do you constructed the Anker-50 or SS60 ?. I want to try it with DD coil. Do you try it ?
                          Yes if take away the bridge is got A -50 with big sensor. Possible, makes sense use the breaker a bridge - 1/2 bridges. The Spool DD too certainly, will work, but I did not try - presently concern with only deep detector.
                          The Best wisheses.
                            Coil
                            Hi Anker. Thanks. Now something about the coil. Is it the same with coil of Anker-50 ?? If all will go ok then i will put a switch to connect the coil at full bridge or at 1/2 bridge and gnd (-12V).
                              The sensor control can be applied as in Anker -50 or any other types or size (Ring, DD, Bigfoot)
                              All best.
