some detector producers claims their detectors finds cavity and light the led which is on control panel.
how can a detector do this
can anybody explain this to me
thanks
Most soil has some amount of mineralization, i.e., ferrous particles. Mineralized soil produces a "ground signal" in detectors, which is why many of them have a ground balance control. When the detector goes over a void, there is less mineralization, and the ground signal is reduced. Detectors can be tuned to signal this decrease.
I haven't kept up with the Delta Pulse, so I don't know. But in most cases, PI detectors don't see ground mineralization as well as VLF, so PI is not a good choice for a cavity detector.
Nokta Dedektör dünyanın en büyük dedektör teknolojisine sahip global bir marka ve Sanayi ve Teknoloji Bakanlığı onaylı Ar-Ge Merkezidir
but does not give tecnical information.
and claims it can detect up to 8 meters without any problem because of it's tank circuit.
what do you think about this unit.
is it vlf.
is it vlf.
I have a question
vlf and bfo detectors are effected from minerals
PI do not .
who can consider bfo and PI for me.
both have one coil winding .think that we we wind them in same sizes and turns.
what will happen.why you say PI s do not effected.
I have a question
PI do not .
BFO and PI detectors work on different principles. The BFO looks for a change in inductance by monitoring the frequency of the oscillator, and is therefore more sensitive to ground minerals. The PI looks for a change in the decay time of the transmitted pulse. In this case the ground matrix is not good at supporting eddy currents, so effectively the ground is ignored.
so we can say if a company insist on finding cavity,it can not penetrate deep like PI.
can we say if soil mineral is low even this machines can not find cavity?
