Hi all. The other day I bought a minelab equinox 900, with all coils 6", 11", 15". shows -19 -18 -17.sometimes even -16.as soon as I didn't tune it, it doesn't help.it doesn't tune out from the background of the ground.In the sound reduction program, there is no way to lower the tone only on these numbers.Only from 0 to -19.All together. Maybe our forum will tell the manufacturer how to improve the device settings ...
EQUINOX 900
Hi all. Yesterday I went out to check the device. You have to tune out from the ground very often so that the device gives less false signals from the ground. -19, -18, -17, -16. if you bring the ground balance to the main panel, it will be much more convenient. And in the detailed settings the ability to cut these numbers.
minelab equinox 900 wants software upgrade. Can someone answer why it was necessary to add iron responses from -10 to -19. Any iron or magnetic object shows up to -12. Only the response from the ground shows from -19 to -15. as soon as you do not adjust the balance.
