Basic Stamp
  • Basic Stamp
    Hi everyone.
    I have been reading about using a basic stamp microcontroller for sensing.
    has anyone here really looked into this as a method for extracting usable data from a PI? I did a search on the forum and only found 1 thread that mentions 1 in passing. I would think that a little programing and coupled the the Hammerhead board we might be able to get a more sensitive detector.
    What prompted this was the new ML gp4000. It seems to be a much better detector now from the reports I have been reading. I am assuming that they are using a/d converters to a microprocessor to produce a much better PI.
    Ray-NM
    Stamp vs PIC uC
    The stamp itself tends to be a little show unless you can run it with a 50 Mhz clock. This is because the Stamp runs in basic so there is high level language overhead whereas using a PIC microcontroller with machine language is plenty fast enough to drive PI MDs and do signal processing. I don't know if the PIC has been used for VLF type MDs or others.
    If you use a PIC with the Analog to Digital converter (A2D) signal processing can also be done on the output of the coil or the PI comparator opamp.
    Goldfinder
      PICs are used in quite a few Tesoro machines. DFX and XLT use Motorola microcontrollers. Minelab VLFs, some Fishers, Bounty Hunters also use a uC, don't remember which ones. Some Garretts use real DSP chips.
      - Carl
        Hi Ray-NM,
        Motorola (Freescale) have a range of micro's that are somewhere between a DSP and a microcontroller that are well worth a look for PIMD type applications.
        Have a peek at:
        www.freescale.com/files/dsp/doc/data_sheet/MC56F8323.pdf
        bugwhiskers
          Thanks for the info
          I am doing a little reading now from all of the information you all have given me. If I come up with anything that works I will post it here.
          RayNM
            Old Bounty Hunter ads say Zilog brand microprocessors. Z86 I believe.... Same family the old TRS-80 used. oops, gave away my age....
