Here is some info I collect about the mode
Unfortunately i don't remember where from
Sorry but i can't give credit to the author
White's XLT Replacement Screen Issues
Well my new display came in and got it installed Screen came on and displayed the correct characters but still have problems..........no backlight . I checked the backlight plug-in on the board and have the correct 5v on the pins . I have the pigtail soldered correctly to the display board 5v and the polarity is correct . I should be getting 5v to the display but I am not . I checked and only measured a bit over 2v . I assume not enough to illuminate the screen . Why would I have the correct 5v on the pigtail and then then when attached to the display board it drops to 2v ? I can hook a independent 5v power supply to the screen and bam it lights up great . What can be causing the drop in voltage with everything connected ? Seems I'm at a loss again ...........
Old PCB = there can be invisible corrosion on soldering points of the connector, resolder them.
How LCD was dying, slowly each day getting worse or rapidly = on one day ok on next day dead ?
could be that you had a bad connection somewhere
why don't you get a contact cleaner spray and clean all contacts on both boards.
make sure that you get a spay with NO oil
Well back to the XLT display problems . This morning I put the suspect replacement display module on a breadboard and connected grounds and power to the appropriate pinouts . To my surprise the screen came on complete with a blue border and a working backlight . This has me thinking my problem may lie with the driver board the display plugs in to . I'd be completely lost trying to figure out component failure on the driver board and am going to try and search out the complete board . I have already converted this board with the resistor mods for the new display . Will the be a compatible driver board available for this application ? I've included a pic of the original one . PS The thing is I did have a working display besides the missing segments before doing the mods .I'm bumfuzzeled .
It's still thicker than the original and it still requires modifications and soldering skills to both it and the driver board . It's no drop in .Originally posted by pito View Post
the same size and pins
https://www.google.com/search?q=wg12...koIEAIYAiACKAI
Installation: It is generally a direct drop-in replacement for the original display module, though proper soldering and, in some cases, adjustment of the contrast potentiometer may be required
https://www.aliexpress.com/item/1005...003436704_1
the same size and pinsOriginally posted by ric44 View Post
There is no direct replacement . .
There is no direct replacement . They were gone long ago . They operated on AC current instead of DC via a converter . The replacement lcd's are 5v DC and are a thicker unit making it necessary to trim the case mounting bosses back to accomodate the extra width . Google replacing the XLT display . It opens up a whole new can of worms . The driver board it sits on has to be modified . It is an involved process and I have found nothing online that shows a step by step process . There are those that make money selling and replacing the displays and are seemingly reluctant to outline the process for the DIY'er . Maybe someone here has pics and can detail the process . If so post up . It would help a lot of people .Originally posted by nickel_n View Post
i was looking for the original part number and the part number of the replacement that was sold as direct replacement.
an 128x64 LCD if i remember well it physically larger than the original
i was looking for the original part number and the part number of the replacement that was sold as direct replacement.Originally posted by pito View Post
Played around a little this morning with the display and a multimeter and I'm thinking I may have found the problem with it . Several of the smd capacitors showed no values and I found one that was open ( marked CF on the board ). Anyhow I got a couple of new LCD's on the way .
