Hi Detectionman. Congratulation. If you have a signal (from tx to rc) at a distance of 10m then you have a theoretically depth of 5 meters. But don't play with discrimination. It is not possible at 2Box detectors. The frequency is fix (it work with the reflect signal), and phase shift the same and the only that changes is the time that needs the signal to go from tx to ground and after the reflection to the receiver. I can't see any way for discrimination. But maybe YOU ????
My wishes
My wishes
to buy a detector. We have hoby to construct a detector or to make it to work better
