INFORMATION
  • #31
    GTI 2500 Imaging Metal Detector
    Hi All :
    Is GTI 2500 able to find GOLD in 5 - 7 meter Depth ?
    Is this True :
    Graphic target imaging is totally new to the world of treasure hunting. Imaging is the ability of a detector to measure the size of buried and concealed metal objects and report that information to the detector user ?
    What about this :
    The GTI 2500 gives you both the size and the actual depth of the targets you locate ?
    And this too :
    A depth multiplier is a specialized searchcoil designed to detect large and deeply buried targets, such as money caches, relics, safes and ore veins. Unlike a regular searchcoil, the transmitter and receiver portions of the depth multiplier are spilt into two compartments, thereby widening and deepening the detection field so that more information about a detected target can be retrieved and processed. Because it ignores small pieces of junk metal, the depth multiplier is especially useful in areas with a lot of trash.
    Pls Helps Out ...
    • #32
      Sisco, my purpose was if these detectors be at optimum condition not deserve to pay more than 400-500 $ as I have used some of them and can daringly tell do the same job that DDL(300$) do.
      (azize dele baradar to inja omadatan masaele teori mibini ta amaili)
      Qiaozhi, what I tell is not based on theories or scientific justification, are completely based on my own gotten results and experiences without any quotation, narrator or interceder, now from your standpoints it's overruled or not is another thing and never can't change my opinions which have been shaped based on those experiences. of course working with these kind of devices are not as easily as one conventional detector like one MD and need so much practice. those just accelerate your search but are not complete as none of available detectors are complete.
      You or other skeptics believe or not, I'm not trying to make money or ad for any body or firm but when I know something that I'm sure about don't spare others and I hate to lie and can't bear lie.
      Morris jo, If you want "everything detector"; metals, minerals, rocks and hot-rocks, ceramics, bricks,mud bricks,.... look for between Whites and Garret detectors they make the best in this case.
      • #33
        map dowsing
        Dear Sisco and chums on this thread, I have searched that site pictured above with Mineoro FG80. Never got a signal even using Dicky Spy screen.
        If you ever go there you will see my name on left hand pillar in marker pen.
        " Delbert was here " If there are secret service men about I prefer map Dowsing from the safety of home. No problem with Dicky Spy as well.
        • #34
          Hi Michael,
          Yes - I realise you are speaking from firsthand experience, and that you do not have a vested interest in promoting this dowsing and LRL nonsense. That's why I respect your input to this forum, and try not to "bash" you too much.
          It is clear that you have had a bad experience with LRLs and have even wasted some money on this junk. Eventually it is my hope that you will leave the Dark Side all together and come to terms with the reality that these devices just do not work. It is well known that dowsing (either in the field, or with maps) is the result of the ideomotor effect. This is a mind trick that mediums and other charlatans use to good effect with ouija boards, table tipping, pendulums, and (of course) dowsing. The ideomotor effect, when coupled with the mind's wonderful ability of selective memory, can make you believe something is true when it is not.
          Perhaps you just need a bit more time. We'll get there in the end.
          • #35
            i know for make this device maximum need to 200$(parts price)
            and remnant of price 5000% gain for manufactury.
            and last line i can't understand mean (is this chat language).
            • #36
              Originally posted by Morris_jo View Post
              Hi All :
              Is this True :
              What about this :
              And this too :
              Pls Helps Out ...
              Here's the link to the Garrett GTI 2500 ->
              http://www.garrett.com/hobby/products/gti2500data.htm
              This detector does not give you a picture of what's underground. It provides an intelligent "guess" of the depth, plus an estimate of the object's size. It does this by having an extra coil in the search head called the imaging coil. The onboard microprocessor can then correlate the readings from the normal receive coil and the imaging coil to make these estimates.
              I very much doubt it could detect anything at 5 to 7m depth, even with the depth multiplier.
              • #37
                Hi Michael,
                Yes - I realise you are speaking from firsthand experience, and that you do not have a vested interest in promoting this dowsing and LRL nonsense. That's why I respect your input to this forum, and try not to "bash" you too .......Perhaps you just need a bit more time. We'll get there in the end.
                Hi Qiaozhi, thank you for your kindly statements.
                in this spring I will tell all our definite deductions and results about this affair (especially about FG80), but sometimes some things happen that change our previous deductions or thoughts e.g. about OKM products that you saw my compatriot results and still no convincing answer how it's possible, whereas before that we as well as me didn't believe them and knew them as bogus.
                • #38
                  No problem. Good luck with your investigations.
                  • #39
                    DELL DDL
                    HI ALL ...
                    AM LOOKING FOR DELL DDL PHOTOS AND PRICE .
                    WHAT ARE THE GOOD DETECTOR FOR TREASUR HUNTER LONG RANG LOCATOR... DEPTH ... ONLY GOLD AND SILVER
                    • #40
                      Originally posted by maimoune View Post
                      HI ALL ...
                      There are no detectors available that can detect only gold and silver, and definitely no long range detectors either (despite the advertising).
                      However, there are some metal detectors that are designed to be more sensitive to either gold or silver. These are induction balance designs that use a higher than normal transmit frequency. Trying looking on the websites of Garrett, Minelabs, Tesoro, etc.
                      In your case, I suspect you are looking for a deeply buried treasure cache rather than gold nuggets, so these types of detector will probably be of little use.
                      If you want to see the reality of detecting a 1kg hoard of coins at a depth of 64cm, then look here ->
                      http://www.garysdetecting.co.uk/hoard_test.htm
                      LRL, DDL, MFD, whatever - forget it, they are just scams.
                      • #41
                        Hi Qiaozhi...
                        thank you
                        we have here in my country meny treasur and all depht are 3meters ... 5meters. my detector TM 808 is not good .Am looking for a small detctor like mineoro , DELL DDL .
                        • #42
                          Save your $$$
                          Hi Qiaozhi...
                          thank you
                          The Dell DDL is a dowsing contraption, and not a detector. Save your $$$ and bend a coat hanger into a L-Rod for the same results.
                          • #43
                            Maimoune , I wrote for you, what did you notice? the address for DDL is here:
                            http://www.omnitron.net/del_prod.htm and its' price is 300$.
                            prepare one transmitter for that or buy it with the transmitter that Dell sells and is matched for DDL (X_scan).
                            but it's necessary to know These are not complete, combine it with a good powerful Metal detector that most are made in Germany take a look for DTI Genesis here:
                            http://www.detector-trade.de/English/DTI-Puls.htm
                            or search for Lorenze Deepmax X3.
                            Based on one report (that I have just heard not seen) in Greece, in combination one kind of homemade LRL with Deepmax X3 one precious gold object has been found at 150 Cm depth.
                            bear in mind that none of detectors are complete you have to have some of them, unless you deice to coin shooting, then one metal detector can be good, I exactly know and understand your situation and what you are searching for.
                            and without any malice want you or any other person around world especially in middle east succeed. when I hear one man in one point of world has found an object , honestly joy and enjoy as if I myself have found it.
                            I tell you friendly ; none of White's or Garrett or other American brands (at this class) are useful, don't waste your money for these trashes I know all , of course the latest Minelab detectors ( made in Australia) are somehow good, but I suggest you; only prepare your MD from the German I wrote. you won't sustain a loss. Good luck.
                            • #44
                              Hi Qiaozhi...
                              thank you
                              If you are looking for a handheld detector with incredible depth, then look here -> http://www.nexusdetectors.com/
                              Especially if you have the Nexus Ultima ("monster") coil. This can detect a 30mm coin at 80cm. http://www.nexusdetectors.com/NexusUltimaproducts.html
                              It's expensive, but it does work!
                              • #45
                                Maybe this clear up some doubts...?
                                About Garrett GTI 2500;
                                I owned it for 3 years....
                                Yes, Qiaozhi is right. "intelligent "guess"" is just proper term for functions installed in this
                                nice machine. Very,very nice detector in case you are prospecting! Remember this!
                                But in my case (since i am only interested in coins), this machine was not quite good choice for
                                my needs, therefore i sold it after 3 descent years of prospecting with it.
                                There are 2 (two) RX inputs in this detector, for 2 RX coils. There are 2 (two) OP37 op-amps which
                                separatelly receive signals from RX coils. In case of using coil with only one RX (Scorcher) other
                                - unused RX is coupled to ground due eventual hums it may produce....
                                About depth;
                                well it depends of many factors, but for sure you cant detect anything on 5-7 meters with it!
                                No chance. GTI 2500 is VLF I/B detector very good for detecting medium and large sized objects
                                on, not more than 1-1.5 meters depth (my own experiences)...
                                Of course i found much coins with it also, but comparing with other good coinshooters, GTI 2500 is
                                nothing special...
                                Also, GTI 2500 lacks of accurate discrimination of targets deeper than 40-50cm....which is the case
                                with almost all VLF's on market today...(White's DFX is a bit better in this case).
                                Estimating the object's size and depth is the major GTI2500 advantage over many other simillar
                                detectors, which makes it very good choice to work with. Those functions are more than 70% accurate.
                                About Nexus.....i am not sure....according to advertisements it is very deep...but having already
                                bad experiences, i can not be sure in those. Simillar case was with Anker...."So deep","so deep" and
                                at the end it turns to be "deep" only in the air. When put on the ground, under real conditions it
                                turns to be uselless due huge instabillity, producing a bunch of false signals all over arround!
                                It should be payed a huge attention on this! Many people are confused about many devices....
                                Laics and beginers are testing detectors mostly in air, gaining good results....
                                But the very same machines showed quite different performances on the ground.WORSE !
                                I know a man, here from Serbia, who is mountebank. He uses to import already prepared kits from
                                Bulgaria. Assembling those, making bad DD coils and selling those as "Extra" deep detectors!
                                Mostly he present his "products" at his home, with already good "prepared" conditions, so those
                                detectors are showing very good performances! Infront of very unexperienced customers, he is
                                showing coin detection in the air, on over 40cm range!
                                He also prepared a piece of ground infront of his home as "test field". He burried a copper
                                plate 40x40cm on 60cm depth. Covered with 20cm soil. Over the top of that he put an ordinary
                                coin...at 40cm depth. So when you want to check his detector....ha,ha,ha...of course it will
                                detect! It looks like detector detected a coin....while real truth is that copper plate is detected.
                                Ha,ha,ha.....I hope this story of mine will not give "some ideas" to some of you!?
                                Fighting with peoples like one mentioned is so hard for me. I am trying to sell my VLF's honestly.
                                My VLF is capable to detect single coin (2cm)at 22-25cm in the ground, which is very good result with
                                20cm coil diamm. So when i advertise my detectors with its performances, people are laughing on
                                me....mentioning that mountebank with "performances" of his "extra" detector.....
                                So, after this and many simillar experiences....what man can think and say here?
                                I do not beleive a thing, until see with my own eyes, and do some tests.....on my own.
                                I have luck to say that i owned many detectors so far. Worked with all of those for some period..
                                I have luck to own descent experience on the field with those.
                                I had chance to test and work with : White's Eagle II, White's DFX, White's Classic 3, Garret GTI2500,
                                Fisher 1266, Fisher CZ5, Fisher CZ7, CSCOPE 1220B, CSCOPE Metadex, Atlantis Imperator, Minelab Relic
                                Hawk, Minelab Musketeer Colt, Minelab X-Terra 70, Minelab Explorer SE, Bounty HUnter (several),
                                Compass (several), Pulse Star II, Snifer XR7 (DBP 2010).....and many more i forgot.
                                So i have very simple resume.....or message to everybody interested here:
                                NONE OF MENTIONED MODELS HERE IS NOT CAPABLE TO DETECT SINGLE COIN DEEPER THAN 40CM IN THE GROUND!
                                NONE OF MENTIONED MODELS HERE IS NOT CAPABLE TO ACCURATELLY DISCRIMINATE COIN UNDER 25CM IN THE GND.
                                NONE OF MENTIONED MODELS HERE(EXCEPT P.STAR II) IS NOT CAPABLE TO DETECT ANYTHING UNDER 1.5 METERS
                                IN THE GROUND ACCURATELLY, NO MATTER SIZE OF COIL!!!
                                When i said 1.5 meters, of course most of mentioned models are not capable to reach even that!
                                Best performance showed Minelab Relic Hawk...by detecting small roman oil lamp (10cm x 5cm) on
                                95cm depth....with very accurate discrimination to non-ferrous !!!!!
                                So, friends, do not be angry on me due my claims, but this is REAL,NAKED TRUTH!
                                I do not beleive in Nexus......sorry Quiaozhi, my friend. As i understood, Nexus is small,
                                independent,private manufacturer (Bulgarian...but in London)......
                                I do respect efforts of any one single conversant man today....but...let's do not fool ourselves!
                                Gigantic companies like White's, Fisher, Garret and Minelab done so far almost everything what
                                can be done !!! PERIOD!!! Does anybody even dare to think that some small independent manufacturer
                                can be smarter and produce better device than those giants...????
                                What do you think; how many,the very best EE's, are working in those companies? Every day! Every
                                hour! So much experiences! So much good conditions for work,experiment,test....
                                Let's don't fool ourselves friends! Please!
                                If you want to see what is "edge of progress" in metal detecting, you only have to take latest
                                product and check it. For example, let's take White's DFX as reference. Or Minelab SD2200...
                                Performances you may see with those machines are REAL "EDGE" of progress in metal detecting
                                so far! Trust me!
                                Of course be awared what are you testing and at what conditions. Do not test "coinshooter" as
                                detector for prospecting or relic hunting, and vice-versa!
                                Do not mix "apples and bananas" please!
                                Do not compare some deep PI with some refined beachcomber....and simillar. Come to think; maybe
                                this is the main reason why so many people are confused these days in this subject???
                                Who knows?
                                Moris Jo....if you want 5-7 meters depth....than forget conventional MD's....Switch to something
                                else for example...How about OKM Gems or Mala Ramac...and everything in between.
                                Here in Serbia we using to say; "Much money - much music!!!"....
                                i can only add: "No money - silence"!
