I have built a device equipped with an antenna. I used an Arduino, a control screen, and a single button. I also added external components: an LM386 amplifier IC, a BD139 transistor, and a 10k variable resistor, along with ceramic and disc capacitors. The setup relies on a ground connection (negative/earth) and an antenna. I also wrote and uploaded the code for it.
However, it is not working. Could the issue be with the code? If anyone has experience or knowledge regarding how the code should be structured, please advise.
